Problem Using Bipolar Transistor as a Switch
6 replies · 2K views · last reply
lindhaw
Im new here and I am currently working on a small IR encoder project. I have the encoder working great but now I need to use the 5vdc signal that comes from the encoder and make it 24vdc. I am currently trying to use a bipolar transistor but its not working. The basic diagram that I am going off of is attached along with the schematic of the optical encoder schematic. Am i way off track or am I missing something obvious.
BTW I am using 20k for R1 and 200K for R2 for the switch
  • Circuit schematic of a two-transistor switch: a 5V supply feeds a 10K pull-up resistor, a 2N3904 NPN transistor with its base driven through a 1K resistor from a photodiode branch, and a 2N3906 PNP transistor whose collector drives an Out terminal through a 1K resistor to ground.
  • Circuit schematic of a PNP transistor switch: +12V supply through R2 to the emitter, base driven through R1 from the input on the left, collector labeled To Load, with ground symbol below.
Welcome to the PF.
Can you run the first stage off of 24V? A 5V pullup stage will not shut off a 24V high-side switch stage...
If you can't run the first stage at 24V, use an open-collector stage to convert from 5V to 24V.
lindhaw said:
I don't think I can do that because I think it would just burn up the emitter and possibly the receiver. I've also been looking into this http://www.goldmine-elec-products.com/prodinfo.asp?number=G18694 but I've never used anything like that so I am not sure if the response time will be fast enough.
Your link is just a DC-DC converter to convert a 5V power supply to a 24V voltage source.
What you want is a way to convert a 5V logic signal to a 24V logic signal, correct?
The way to do that is with an open-collector BJT stage. Are you familiar with those yet?
Ya that's correct. I am not familiar with those yet. Is that something that I could make or is that something that I should just buy?
ok dumb question sorry I just looked it up and I think i can manage one of those. Thanks for the advice! Ill let you know how it goes!
