Problem Using Bipolar Transistor as a Switch
  • Thread starter Thread starter lindhaw
    Switch Transistor
6 replies · 2K views
lindhaw
Im new here and I am currently working on a small IR encoder project. I have the encoder working great but now I need to use the 5vdc signal that comes from the encoder and make it 24vdc. I am currently trying to use a bipolar transistor but its not working. The basic diagram that I am going off of is attached along with the schematic of the optical encoder schematic. Am i way off track or am I missing something obvious.
BTW I am using 20k for R1 and 200K for R2 for the switch
Welcome to the PF.
Can you run the first stage off of 24V? A 5V pullup stage will not shut off a 24V high-side switch stage...
If you can't run the first stage at 24V, use an open-collector stage to convert from 5V to 24V.
lindhaw said:
I don't think I can do that because I think it would just burn up the emitter and possibly the receiver. I've also been looking into this http://www.goldmine-elec-products.com/prodinfo.asp?number=G18694 but I've never used anything like that so I am not sure if the response time will be fast enough.
Your link is just a DC-DC converter to convert a 5V power supply to a 24V voltage source.
What you want is a way to convert a 5V logic signal to a 24V logic signal, correct?
The way to do that is with an open-collector BJT stage. Are you familiar with those yet?
Ya that's correct. I am not familiar with those yet. Is that something that I could make or is that something that I should just buy?
ok dumb question sorry I just looked it up and I think i can manage one of those. Thanks for the advice! Ill let you know how it goes!
