Calculating Q for a Series LC Circuit: Where Did I Go Wrong?
  • Thread starter Thread starter Idea04
    Calculations
In a series LC circuit, the quality factor Q is calculated using the formula Q = XL / R, where XL is the inductive reactance and R is the resistance. The original calculation of Q = 1/R√(L/C) resulted in an implausibly high value of 111.86, prompting a reevaluation. The circuit resonates at a specific frequency, which needs to be determined to find the correct reactance values. After recalculating with the given inductor and capacitor values, a more reasonable Q of approximately 12.6 was obtained. Clarification of the calculations and resonance frequency is necessary for accurate results.
Idea04
For a series LC circuit the Q I believe is Q= 1/R^(L/C). I have a 1.923 Henry inductor and a 4.4uF cap. The resistance in the inductor is 52.5 ohms. The answer I got was 111.86.
I know the circuit can't have a Q of that value. Where did I go wrong?
This looks like homework, so I'll just describe the process.
The frequency wasn't given, so I guess you mean at resonance.
The circuit resonates at ... Hz.
The reactance of the coil and capacitor at resonant frequency is ... ohms.
Q= XL / R
I get a Q of about 12.6.
I thought it might be homework as well, but I'm not sure. Idea, could you please post your math so we can check it? Thanks.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 30 ·
  • · Replies 19 ·
  • · Replies 32 ·
