Problems in Copper and Zinc Electroplating
9 replies · 3K views · last reply
hojess02
TL;DR
Hi~
Pic 1: The first time we electroplated iron nail with copper. The surface of the nail had black substance after electroplating it.
Pic 2: The second time we did it & we used a lower concentration of copper(II) sulphate as electrolyte.
I wonder is that black substance copper oxide & what is the relationship between that black substance and the concentration of copper(II) sulphate.
Thanks!!
A red-coated screw with a silver-colored head lying on a folded white cloth on a grey surface.
  • Hand holding a black-clipped copper electrode dipped into a glass beaker of blue copper sulfate solution, with a red-clipped metal electrode in the solution and a power supply in the background.
Welcome to PF. :smile:
Can you say more about your plating setup? What settings are you using? How long are you letting the plating process run?
Cu plating on an iron nail is spontaneous. You shouldn’t have needed any current. What was the other electrode made of? Were those galvanized nails?
With current the process can be definitely speed up (and you can plate much thicker layers).
We used 3.0V (combination of two 1.5V batteries), copper plate, iron nail, 2 wires with crocodile clips, copper(II) sulphate solution (about 0.5M) (We didn't measure the concentration precisely) ThxThx
I see... Is zinc electroplating on iron spontaneous too? Since zinc has a more negative standard electrode potential. Those were non-galvanized nails.
I see... thanks!
You are using two iron nails for electrodes. Only one will produce copper. Which one is black? Anode or cathode?
There is a problem with OP post formatting, but I believe they used copper plate for the anode.
