Producing Martensite & Bainite in Carbon Steel
This discussion focuses on the production of martensite and bainite in carbon steel, specifically using an Fe-0.45C alloy. Martensite is formed through rapid cooling from the austenite phase, while bainite requires an intermediate cooling rate, which is neither too fast nor too slow. The participant heated the alloy to 760 degrees Celsius and quenching it in water for 20 seconds, but observed uneven hardness across the test piece. The discussion emphasizes the importance of using a Time-Temperature-Transformation (TTT) diagram to predict microstructural outcomes from heat treatment.
  • Understanding of phase transformations in steel, specifically martensite and bainite.
  • Familiarity with heat treatment processes, including quenching and tempering.
  • Knowledge of the TTT diagram and its application in predicting microstructure.
  • Experience with carbon steel alloys, particularly Fe-0.45C.
  • Study the TTT diagram for Fe-0.45C to understand phase transformations.
  • Research the effects of different quenching media on hardness and microstructure.
  • Learn about Austempering heat treatment and its role in producing bainite.
  • Explore the relationship between cooling rates and microstructural outcomes in steel.
Metallurgists, materials engineers, and anyone involved in heat treatment processes of carbon steel looking to optimize the production of martensite and bainite.
tututu87
How to 'produce' martensite and bainite?
For what i know, martensite formed by rapid cooling from austenite phase of steel, and slow cooling to form back to it's original state. But in order to form bainite, what's the cooling rate? intermediate between rapid and slow cooling? How rapid and how slow is it exactly?
I heated up furnace temp to 760 degree Celsius (1400 F), and put in Fe-0.45C for nearly 20 mins(what phase is this Fe-0.45C falls after i quench it for 20 seconds, with water as quenching media?), but the hardness readings were not equal over the whole test piece.
Is it because of the quenching media, which never equally cool for the test piece, or it is due to the quenching time?
I guess the better way to preditc a microstructure result from a heat treatment is looking for the TTT diagram for your alloy.
From the cooling rate you may sketch the curve and analise the initial and final points in the diagram curves for phase transformation.
An example of TTT diagram:
http://www.msm.cam.ac.uk/phase-trans/2000/practicals/AP3/Image5.gif
PS.: The Bainite structure can be obtained from an Austempering heat treatment.
I hope i'd been helpful
regards
Taxt
12K
11K
