Projectile motion ball throw problem
1 reply · 3K views · last reply
herbgriffin
A ball is thrown upwards from the top of a building with an initial velocity of 20 m/s and at an angle of 30 (degrees) with the horizontal. The height of the building from the ground level is 25m. Determine (i) where and when it will strike the ground (ii) velocity with which it strikes the ground (iii)maximum height reached by the ball above the ground level.
T total = (2Vi sin(theta))/2(9.81)
Range, R= (Vi)^2 sin2(theta)/ (9.81)
i have solve for Vx= 20cos30 = 17.32 m/s
Vy=20sin30= 10 m/s
There are 4 or 5 equations relevant to projectile motion, and they should all be in your textbook.
There are problems with the two equations you list here. The first equation should contain initial and final velocities, but only has the initial velocity. Also, that range equation is only valid for the projectiles launched from ground level -- not the case here.
Vy=20sin30= 10 m/s
[/QUOTE]
I would start by finding how long it takes the ball to hit the ground. Check out the equations for projectile motion, and see which can be used to find time t given the information you know about height, initial velocity, and acceleration in the y (vertical) direction.
