Projectile Motion Calculations for a Shell Fired at 30 Degrees
A shell is fired at a 30-degree angle and remains airborne for 40 seconds, prompting calculations for its range and maximum height. To find the horizontal distance it lands from the original position, the projectile motion equations can be applied, specifically focusing on time of flight and initial velocity components. The highest point can be determined using the vertical motion equations, factoring in gravitational acceleration. Clarification is sought on whether the 40 seconds refers to time or velocity, indicating confusion about the problem's parameters. Understanding the correct application of projectile motion equations is essential for solving the problem accurately.
mc2_phy
A shell is fired at an abgle of 30 degrees to the horizontal. If the shell stays in the air for 40 seconds, calculate
a)how far it lands from it's original position
b)the highest point it can reach
N/a
I was unparticularly sure because the q says 40 seonds- should it be 40m/s
Is
v = v_{0} +gt
a familiar equation?
Use your linear motion equations.
v = u+gt
s = ut + 0.5gt^2
and v^2 = u^2+2gs
make an inventory of what parameter values you have and see which equation suits it best...
No not really. Just wondering how you solve this.
thank you.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
