Projectile motion of home run ball
The discussion revolves around calculating the minimum initial velocity required for a baseball to clear a 12-foot fence located 350 feet from home plate, considering various launch angles (15°, 30°, 45°, and 60°). Participants share equations related to projectile motion and assist in deriving the initial velocity (v0) using these formulas. The user successfully calculates v0 for each angle and seeks guidance on plotting the trajectory in Excel. Ultimately, they express gratitude for the assistance received, noting a significant learning experience throughout the process. The thread highlights the importance of understanding projectile motion in practical applications like baseball.
mlbuxbaum
major league baseball outfield fences are typically 350 feet away from home plate. Home run balls need to be at least 12 feet off the ground to clear the fence. Calculate the minimun required initial velocity( in mph ) for a home run, for baseballs hit at 15°, 30°, 45°, and 60°. Also given was the height at which the ball was hit from, 3 feet off the gound. Gravity is taken into consideration, 32.2 feet/sec^2.
I need to put the above information into an Excel worksheet and generate a chart for each of the angles above, and i need a formula i can grasp. The teacher gave us one but it just confuses me.
vx=v0costheta0
X=v0tcostheta0
t=x/v0costheta0
vy=v0sintheta0-gt
y=y0+xtantheta0-1/2g(x2/v02cos2theta0)
I don't know if i entered the formulas correctly above or not using the sub and sup scripts forms. The only knowns i have are x is initially 0 and y0is initially 3. I have got provide 11 points on an x y chart and plot the graphs. I need help in figuring out the equation inputs and the equation itself. I really hope this makes sense to someone.
hi mlbuxbaum! :smile:
i'm not really grasping what the difficulty is …
you've been given the equations …
mlbuxbaum said:
X=v0tcostheta0
… can't you just plug the given angles in, and draw the charts? :confused:
I don't know v0?
Am i correct in assuming that the only values of x&y i have are (0,3) and (350, 12)? and that i plug those values into the equations to get the quadratic? Sorry if i am frustarting you. I am trying really.
To find V0 would i divide both sides (the x equation) by t(cos\theta) to get what V0 is? with t being my x coordinates? 0 to 350?
i'd put in slightly differently …
you have two simultaneous equations in t,
so you find a formula for t from the x equation, and substitute that for t in the y equation
t=x/v0cos\theta0
i then substitute that value for t into the equation
y=y0+xtan\theta0-.5g(x2/v02cos2\theta)
(have a theta: θ :wink:)
that's right!
so what do you get? :smile:
So you have got the final equation for the x,y coordinates along the path of the projectile.
mlbuxbaum said:
y=y0+xtanθ0-1/2g(x2/v02cos2θ0)
The ball must be at least 12 feet hight at 350 feet distance from the home plate (if only I knew what the home plate is... )So it must pass the point (12;350). Choose a θ0 and plug in x=350, y=12, and solve the equation for v0. You can make an excel table with θ0, v0 and plot v0 as function of θ0. I think you even can make Excel compute v0 for each θ0 if you express v0 in terms of x,y and θ0.
ehild
that's right!
y=3+x(.2679)-16.1(x2/v02(.9330))
using 32.2 ft/sec2 for g
(have you missed out an x ?)
the object is to find v0
what do you get for v0 ?
i fixed the missing x.
Finding v0 is where i am having my issue. I'm not sure how to get it alone
12=3+.2679x-(16.1x2/.9330v02
.9330(12-3-.2679x/-16x2)=v02
\sqrt{}.9330(12-3-.2679x/-16x2)=\sqrt{}v02
v0=\sqrt{}.9330(12-3-.2679x/-16x2)
Plug in the value given for x (x=350) and check the parentheses.
"12=3+.2679x-(16.1x2/.9330v02" is wrong.
Correct: 12=3+0.2679-16.1x2/(0.9330v02)
Continue from here.
ehild
Continue from here.
ehild[/QUOTE
Did you forget the x after class .2679?
mlbuxbaum said:
ehild[/QUOTE
ops! yes. So it is 12=3+0.2679x-16.1x2/(0.9330v02)
i went to the tutor on campus yesterday and he walked me through the problem. The tutor had the same class, same instructor, same problem a few years ago.
12=3+(v0sin15)(350/v0cos15)-.5(32.2)(3502/v02cos215)
so plugging numbers in and working it through
9=350tan15-16.1(131295.1043/v02)
working it through again...
-84.78= -2113851.179/v02
to get v02 alone.
-2113851.179/-84.78 = v02
v0=\sqrt{}-2113851.179/-84.78
v0=157.9 feet/sec
now i need to figure out how to get the x values needed via the quadratic equation
x is the distance of the fence from the home plate. It is 350 feet. Just use the equation the teacher gave you
9=350 tan(theta0)-16.1*122500/(v02cos2theta0) and plug in the angles one by one and calculate v0 for each angle.
ehild
ehild
I worked the V0 for 15 degrees to be 157.9030425
30 degrees at 116.7051809 45 degrees at 107.5520743 and 60 degrees at 114.9329655
now i need to find out how to find the eleven (x,y) coordinants i need to use so i can plot a curve. I am inputting the formulas into my excel worksheet and what would i use for 't' ?
Why do you need the time? You have to make a vo(theta) plot, don't you? Vo can be expressed in terms of theta and input to your Excel worksheet and calculated for as many theta as you like. For example, you can start from 10° and step by 5 degrees up to 60°.
The expression for vo is: vo=1404.37/[cos(theta)√(350 tan(theta)-9)]. Input this equation into Excel.
Anyway, your results for vo at 15, 30, 45, and 60 degrees were correct. Good job!
ehild
thank you for your help. I inserted the equation into my x,y chart in the y column. I started my x column at 0 and y column at 3. I need 11 x,y points for my chart (per the instructor) so i divided 350 by 11, and each division workes out to be ~31.82. So now i have my x value to plug into the equation. I can try and post my final x,y charts for 15,30,45 and 60 degrees and their respective plots. Not sure how to do that but i'll try.
Thanks to you and Tiny Tim for all the help.
ehild
I used this in the column for my unkown Y value
=y0+xtan\theta-.5g(x2/v02cos\theta)
i used my calculated x values and the radian values for 15,30,45, and 60 degrees
i entered in your formula and it doesn't equal what i got. What is 1404.37?
Do you want to plot out the orbit of the ball at the given angles? If so, use x values from 0 to 150 or so, and use vo you calculated for the given angle. There will be four curves and you can compare the orbit of the ball if you throw it at different angles and with different initial speeds.
What I said is how to use Excel to calculate the vo values at given angles. That 1404.37 is the squre root of (g/2 *x2).
ehild
you are correct, that is what i needed to do. I just wanted to put the formula into excel that would calculate v0.
I have attached my file.
Oh, this is simply beautiful. Really. You did it very well!
ehild
ehild
Thank you. If it wasnt for the help of you two guys, i would still be scratching my head. I have some polishing to do on the final copy, but the data is there now. And best of all, i actually learned a few things in the process...cool.
Thanks again guys !
