Projectile Motion Problem: Finding Distance and Collision between Two Particles
The discussion revolves around a projectile motion problem involving two particles shot from points P and Q towards each other. The goal is to find the distance between the particles when one is directly above the other and to prove conditions for their collision based on the angles and speeds involved. Participants clarify the setup, emphasizing that PQ is the horizontal distance between the two points and that the particles can indeed be vertically aligned. The equations of motion are discussed, including how to derive the time when the particles are at the same horizontal position and how to account for gravity in their vertical motion. The conversation highlights the algebraic challenges in solving for the time and height of the projectiles, ultimately leading to the conclusion that the heights of the particles must be equal for a collision to occur.
FaraDazed
Points P and Q are in the same horizontal plane at a distance d metres apart. A projectile is shot from P in the vertical plane through PQ towards Q with a speed v m/s at an angle θ. Simultaneously another particle is shot from Q in the same vertical plane towards P with a speed of 2m/s at an angle of elevation α .
Find an expression for the distance between the two particles when one is vertically above the other one and hence prove that they collide if sin \alpha = \frac{1}{2} sin\theta.
If \theta= \frac{1}{3}\pi prove that they collide at a point above the level of PQ if...
v^2 > \frac{gd(\sqrt{13}-1)}{6\sqrt{3}}
equations of motion
I just don't know how to approach this one at all. I don't want to just be given the answer, just some advice or help in how to approach the problem and any assumptions would be very very much appreciated.
I cannot understand the setup. Is PQ the line joining P and Q ? Also, if P and Q are in a horizontal plane, how can P or Q be vertically above the other ?
I think that's what it means when it says PQ - being the line/distance joining the two. And, sorry about the second bit that was my fault copying the question down; P and Q are points on the plane, its the particles that are fired from P and Q that are/will be above each other.
Thanks
OK. You can find the the time when the projectiles are above each other by solving xP=xQ where
xP= vt cos(θ) and xQ= d-vt cos(α)
Does this help ?
[edit] I made a mistake, I've corrected it.
Thanks, isn't the x cordinate of a projectile in this situation generally speed*t as in v\cos(\theta) t though?
If i set them both to equal each other though I would get stuck as there is nothing I can do to manipulate it, is there?
v\cos(\theta)=d-v\cos(\alpha)
I'm sorry you got caught by my mistake. I've edited my post so you can find the time now, and plug it into the equations for y to get the heights.
You get the time from ##vt\cos(\theta)=d-vt\cos(\alpha)##
OK thank you.
I am stuck with the algebra side of it then I think as I cannot see how to extract t from that. Plus not knowing either of the angles is confusing the hell out of me, I suppose if t is found then the alpha angle could be found as it states the speed for that one (2m/s).
The value of t when the projectiles are at the same x is
##vt\cos(\theta)=d-2t\cos(\alpha)\ \ \rightarrow\ vt\cos(\theta)+2t\cos(\alpha)=d\ \ \rightarrow t_s=\frac{d}{v\cos(\theta)+2\cos(\alpha)}##
The y values are
##y_P=vt\sin(\theta),\ y_Q=2t\sin(\alpha)## put ##t_s## into these and then subtract them.
corrected in my next post
You need to do the algebra.
Likes 1 person
##vt\cos(\theta)=d-2t\cos(\alpha)\ \ \rightarrow\ vt\cos(\theta)+2t\cos(\alpha)=d\ \ \rightarrow t_s=\frac{d}{\cos(v\theta)+2\cos(\alpha)}##
The y values are
Thanks for your help. :)
With the y values, doesn't gravity need to be accounted for?
Yes. Sorry I'm making a lot of mistakes. The y equations (assuming that the initial height is 0) are
##y_P=\int(v\sin(\theta)-gt) dt=vt\sin(\theta)-(1/2)gt^2## and ##y_Q=\int(2\sin(\alpha)-gt)dt=2t\sin(\alpha)-(1/2)gt^2##
So the difference in height is ##vt\sin(\theta)-2t\sin(\alpha)## and the Y-values are equal (for t>0) only if ##v\sin\left( \theta\right) \,=2\,\sin\left( \alpha\right)## which is *not* what is given for this condition.
Likes 1 person
  • · Replies 21 ·
  • · Replies 38 ·
