Projecting vectors from R3 onto a subspace
  • Thread starter Thread starter Ghost of Progress
    Subspace Vectors
To project a vector from R3 onto a subspace defined by the basis [a, b, c]T, the projection formula p = (<u,v>/<v,v>)*v is applied, where v is the basis vector and u is the vector to be projected, typically represented as [x, y, z]T. The derived projection results in a vector p that reflects the components of u along the direction of v. The discussion also addresses finding the projection matrix P for projecting onto the orthogonal complement of a two-dimensional subspace spanned by vectors x1 = [1, 0, 2]T and x2 = [0, 1, -2]. The calculated orthogonal complement basis is [-2, 2, 1]T, leading to a projection matrix P that is confirmed to be correct based on the provided definitions. The overall focus is on ensuring the accuracy of the projection calculations and the formulation of the projection matrix.
Ghost of Progress
I want to project a vector from R3 onto a subspace.
I'll let the bases for the subspace be [a,b,c]T
(my T's mean transpose)
I have the defintion for vector projection
p = (<u,v>/<v,v>)*v
I know v will be the [a,b,c]T vector but what is u?
The only thing I could think of is let it be the triplet [x,y,z]T which could be any vector in R3.
Using this I get
p = [(a/(a^2 + b^2 + c^2))(ax + by + cz)]
[(b/(a^2 + b^2 + c^2))(ax + by + cz)]
[(c/(a^2 + b^2 + c^2))(ax + by + cz)]
I'm not very confident with this solution, I was hoping someone could tell me if this is correct or show me where I've gone wrong.
u is presumably the vector you want to project onto the subspace.
I was just working an a problem that askes me to find the projection matrix P that projects vectors in R3 onto the orthoginal compliment of a two dimensional subsapce of R3 spanned by
x1 = [1,0,2]T x2 = [0,1,-2]
I've found that the bases of the orthoginal compliment is [-2,2,1]T
Using the defintion of P that a posted above I've found
P = [(-2/9)(-2x +2y +z)]
[ (2/9)(-2x +2y +z) ]
[ (1/9)(-2x +2y +z) ]
where, like you said, u = (x,y,z) = the vector I want to project onto the subspace. Does this seem like a correct solution?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
11K
