Can Three Non-Collinear Points Always Define a Projective Plane?
Three non-collinear points in a projective space P(W) of dimension greater than or equal to 2 can always define a projective plane. By assuming the points are distinct, they span a vector space S of dimension 3, which implies that the projective space P(S) has dimension 2, thus forming a plane containing the points. This reasoning extends to higher dimensions, as the points remain linearly independent, spanning a three-dimensional vector space that serves as a subspace of W. Consequently, the projective space P(V), where V is the span of the three points, is the required projective plane. Therefore, the assertion that three non-collinear points define a projective plane holds true.
Euler2718
Let P(W) be a projective space whose dimension is greater than or equal to 2 and let three non-colinear projective points, [v_{1}],[v_{2}],[v_{3}]\in P(W). Prove that there is a projective plane in P(W) containing all three points.
[/B]
For n=2 my reasoning was: WLOG assume [v_{1}],[v_{2}],[v_{3}] are distinct. Then, define s = \{ v_{1},v_{2},v_{3} \} which spans a vector space, S. The dimension here is 3, and since v_{1},v_{2},v_{3}\in S it follows that [v_{1}],[v_{2}],[v_{3}]\in P(S), has dimension two and is thus a plane containing the points.
If this idea is correct, then I am at the point now where I am trying to prove it for all dimensions greater than 2. I was thinking that is P(W) had dimension n (>2) , s = \{ v_{1},v_{2},v_{3} \} still spans a three dimensional vector space which would be a subspace of W. So the projective space of S would be a linear subspace of the projective space of W?
First, there is no need to ask that the points are distinct. They are non colinear, so projectively independent. It also follows that ##v_1, v_2, v_3## must be linearly independent in ##W##, so they span a three-dimensional vectorspace. Now, it is sufficient to define ##V = span\{v_1,v_2,v_3\}## and then say that ##P(V)## is the subspace of ##P(W)## you are looking for. Note that ##P(V)## is a plane, as it has dimension 2.
Likes Euler2718
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
