MHB How to Prove This Complex Inequality Involving Factorials and Sums?
  • Thread starter Thread starter klim
    Inequality
klim
Hallo, can someone help me to proof this inequality:
$$ (\lambda-(m+1)) \cdot \frac{m!}{\lambda^{m+1}} \cdot \sum_{j=0}^m \frac{\lambda^j}{j!} (m+1-j) \leq \frac{\lambda}{\lambda-m} $$
with condition $$ m+1 < \lambda $$.
$$\lambda$$ is real und $$m$$ is integer.
Proof:Let f(m) = (\lambda-(m+1)) \cdot \frac{m!}{\lambda^{m+1}} \cdot \sum_{j=0}^m \frac{\lambda^j}{j!} (m+1-j).We want to show that f(m) ≤ \frac{\lambda}{\lambda-m} for m+1 < \lambda.Since f(m) is a continuous function, we can use the Mean Value Theorem to show that there exists a c ∈ (m,m+1) such thatf'(c) = \frac{f(m+1)-f(m)}{m+1-m} = \frac{f(m+1)-f(m)}{1}.Butf(m+1) = (\lambda-(m+2)) \cdot \frac{(m+1)!}{\lambda^{m+2}} \cdot \sum_{j=0}^{m+1} \frac{\lambda^j}{j!} (m+2-j)andf(m) = (\lambda-(m+1)) \cdot \frac{m!}{\lambda^{m+1}} \cdot \sum_{j=0}^m \frac{\lambda^j}{j!} (m+1-j).Substituting in f'(c) gives:f'(c) = \frac{(\lambda-(m+2)) \cdot \frac{(m+1)!}{\lambda^{m+2}} \cdot \sum_{j=0}^{m+1} \frac{\lambda^j}{j!} (m+2-j) - (\lambda-(m+1)) \cdot \frac{m!}{\lambda^{m+1}} \cdot \sum_{j=0}^m \frac{\lambda^j}{j!} (m+1-j)}{1}.Simplifying this expression gives:f'(c) = \frac{(\lambda-(m+1)) \cdot \frac{(m+1)!}{\lambda^{m+2}} \
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
