Proof of the derivative
184
Main Question or Discussion Point
What's the proof for the derivative?
[tex] \frac{d}{dx} x^n = nx^{n-1} [/tex]
(once again, i've stuffed up the latex and can't fix it!)
It should read d/dx x^n = nx^(n-1)
Answers and Replies
1,073
Hurkyl
Staff Emeritus
Also, look here for LaTeX help:
https://www.physicsforums.com/showthread.php?t=8997
The thing you're missing is that you have to use braces {} if you want to group a collection of things into one object (like an exponent).
HallsofIvy
41,738
897
You prove the general power rule by using proof by induction and the product rule.
When n= 1, [itex]\frac{dx}{dx}= 1= 1x^0[/itex] so the formula is true.
Assume [itex]\frac{dx^k}{dx}= kx^{k-1}[/itex]. Then
[tex]\frac{dx^{k+1}}{dx}= \frac{d(x(x^k))}{dx}= x\frac{dx^k}{dx}+ \frac{dx}{dx}(x^k}[/tex]
[tex]= x(kx^{k-1}+ 1(x^k)= kx^k+ x^k= (k+1)x^k[/tex]
682
what if n is not an integer, an irrational number for example. Then how can one prove it without using newton's series?
I know one can prove the rule for rational number using chain rule and implicit differentiation, but what about irrational numbers?
dextercioby
Insights Author
12,965
536
The generalized binomial formula will solve it. That's right, the one expressing Pochhammer's symbols in terms of the Gamma function.
Daniel.
HallsofIvy
41,738
897
For n not a positive integer, use logarithmic differentiation:
If y= xn, then ln y= n log x.
[tex]\frac{1}{y}\frac{dy}{dx}= \frac{n}{x}[/tex]
[tex]\frac{dy}{dx}= \frac{ny}{x}= \frac{nx^n}{x}= nx^{n-1}[/tex]
matt grime
9,394
Or you could use the fact that for non integer/rational exponents the definition of x^k is exp(k logx).
488
that logrithmic one is clever, ill have to remember that. i always got myself going in circles with induction :(
Hi, would you know the name of the classic proof that doesn't use induction?
I have been looking for it but dont know how it was done.
In my first calculus class at the moment and we have been asked to locate it.
thanks.
93
theres a proof of the power rule involving the binomial theorem. It shuold be in your textbook.
That is in the textbook.
But as an extra assignment he challenged us to look for the classic proof.
Said it was messy and took a good page to write up. It is most likely found in old calculus books. Thats all I've got.
thanks for the reply though,
HallsofIvy
41,738
897
Then google on "binomial theorem" "power rule"
thats like saying go look in a book.
No help whatsoever.
HallsofIvy
41,738
897
No help whatsoever.
That's very insulting to the person who asked the question. Are you implying that he can't read?
360
f(x)=xc,f'(x)=?
[tex]\triangle f=(x+\triangle x)^c -x^c=\left(x+(1+\frac{\triangle x}{x})\right)^c-x^c=
x^c\left(\left(1+\frac{\triangle x}{x}\right)^c-1\right)[/tex].
[tex]\frac{\triangle f}{\triangle x}=x^{c-1}\cdot \frac{\left(1+\frac{\triangle x}{x}\right)^c-1}
{\frac{\triangle x}{x}}=x^{c-1}\cdot \frac{(1+u)^c-1}{u};u=\frac{\triangle x}{x}[/tex]
Lemma:
[tex]\lim_{u\to 0}\frac{(1+u)^c-1}{u}=c[/tex]
Proof:
Let [tex](1+u)^c-1=\phi [/tex].
Becouse the function (1+u)c is continous and defined in u=0 we conclude:
[tex]\lim_{u\to 0}(1+u)^c =1\longrightarrow \lim_{u\to 0}\phi =0[/tex].
[tex](1+u)^c=1+\phi\rightarrow c\cdot ln(1+u)=ln(1+\phi);\frac{c\cdot ln(1+u)}{ln(1+\phi)}=1
\longrightarrow \frac{(1+u)^c-1}{u}=\frac{\phi}{u}=\frac{\phi}{u}\cdot\frac{c\cdot ln(1+u)}{ln(1+\phi)}=
c\frac{\phi}{ln(1+\phi)}\cdot\frac{ln(1+u)}{u}[/tex]
c\cdot\lim_{\phi \to 0}\frac{1}{\frac{1}{\phi}ln(1+\phi)}\cdot \lim_{u\to 0}\frac{1}{u}ln(1+u)=
c\lim_{\phi \to 0}\frac{1}{ln(1+\phi)^{1/\phi}}\cdot \lim_{u\to 0}ln(1+u)^{1/u}=c[/tex]
(Becouse [itex]\lim_{u\to 0}(1+u)^{\frac{1}{u}}=ln\ e=1[/itex]).This concludes proof of the lemma.
Therefore:
[tex]f'(x)=\lim_{\triangle x \to 0}\frac{\triangle f}{\triangle x}=x^{c-1}\lim_{u\to 0}
\frac{(1+u)^c-1}{u}=x^{c-1}\cdot c[/tex]
QED
Daniel.
Possible.
But why tu use nuclear weapon when one can kill prey by a bow and arrow?
arildno
Dearly Missed
9,946
130
Define, for all x:
[tex]Exp(x)=1+\sum_{i=1}^{\infty}\frac{x^{i}}{i!}[/tex]
This can be proven to be differentiable, with Exp'(x)=Exp(x).
Also, Exp(x) is invertible, so it has an inverse function Log(x).
Now, Log'(x)=1/x, because:
[tex]x=Exp(Log(x))\to1=x*Log'(x)[/tex]
From which it follows trivially.
Now, for any x>0, we may define:
[tex]x^{c}=Exp(cLog(x)),c\in\mathbb{R}[/tex]
Thus, the result required follows easily.
mathwonk
10,743
919
derivative means "linear part of the change in y".
so just expand (x+ h)^n and look at tbhe coefficient of the linear part of the change, i.e. of (x+h)^n - x^n. the linear term (in h) will have coefficient
nx^(n-1).
thats all. derivatives are pretty trivial for polyonm ials. they do not get tricky until you go to transcendental functions.
e.g. (x+h)^3 - x^3 = 3x^2 h + 3 xh^2 + h^3, so the linear part in h, is 3x^2 h, and the coefficient is 3x^2, which is therefore the derivative.
mathwonk
10,743
919
of course there is a fancy much more difficult limit definition of derivatves that can be checked to agree with this, but I think it is pretty stupid to use that approach to find the derivative of a polynomial.
that approach is only needed for sin or cos, or log or exp.
Related Threads for: Proof of the derivative
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
