Proof that the world is not flat
73 replies · 9K views
Whitehole
I'm reading the book by Zee, I came across a paragraph saying that the world is not flat.
"Given an airline table of distances, you can deduce that the world is curved without ever going outside. If I tell you the three distances between Paris, Berlin, and Barcelona, you can draw a triangle on a flat piece of paper with the three cities at the vertices. But now if I also give you the distances between Rome and each of these three cities, you would find that you can’t extend the triangle to a planar quadrangle (figure 1). So the distances between four points suffice to prove that the world is not flat."
What does he mean by "You would find that you can’t extend the triangle to a planar quadrangle. So the distances between four points suffice to prove that the world is not flat."? I can't depict what he wants to say here, can anyone help explain this?
You cannot find a point on the paper to represent Rome with all of the distances to scale.
If I give you "crow's flight" distances between three points reasonably close together on the Earth's surface, you can always draw a triangle with sides of those lengths on a piece of paper. If I give you the distances from two of these points to a fourth one you can add it to the diagram (there's an ambiguity about which side of the line between the two points the new one lies, but that's all). However, the distance you measure on your piece of paper between the fourth point and the third will not match the distance on the Earth's surface. This is what the dotted lines in the diagram represent - one of their lengths does not match the "crow's flight"
I'm sure Google will furnish the distances beteen the named cities if you'd like to try it. You only need a ruler and a compass.
Alfred Wallace of Darwin-Wallace fame won a cash prize for an experiment that proved the Earth wasn't flat.
Oh, so you mean Zee is simply comparing the distance measurements from the paper to the actual distances of those COUNTRIES/points?
Assume that, after giving the three distances between Paris, Berlin, and Barcelona, he only gives the distance between Rome and Paris, and the distance between Rome and Barcelona. You can then draw two circles on your flat piece of paper (one around Paris, one around Barcelona) with the given distances as radius (scaled), and you then know that Rome must lie on one of the two intersection points of these two circles.
That will give you two possible distances between Rome and Berlin. None of these will match the figure for the actual distance between Rome and Berlin.
He's comparing the distances drawn on a Euclidean plane to the ones along the Earth's surface and concluding that the Earth's surface is not a Euclidean plane, yes.
No, just the ratios of the distances.
Yeah I got it but what does he exactly mean by saying "you can't extend the triangle to a planar quadrangle"? What does it have to do with the measurement mismatch?
See post #2.
You extend the triangle into a quadrilateral by adding a fourth point. But there is no way to add a fourth point to a Euclidean plane such that the distances between all four points match the distances measured on the surface of the Earth. That's all Zee means. From that, you infer that the surface of the Earth cannot be a Euclidean plane.
Following Ibix's suggestion, here's an interesting calculation...
http://www.wolframalpha.com/input/?i=distance+paris+to+berlin (546mi)
http://www.wolframalpha.com/input/?i=distance+paris+to+barcelona (515.2mi)
http://www.wolframalpha.com/input/?i=distance+barcelona+to+berlin (931mi)
http://www.wolframalpha.com/input/?i=area+of+a+triangle+with+sides+546,+515.2,+931 (118474 sq mi)
http://www.wolframalpha.com/input/?i=triangle+with+sides+(rome+to+barcelona),+(rome+to+berlin),+(barcelona+to+berlin) ( 196679 sq mi)
Those triangle areas total to 315153 sq mi.
Using the other pair of triangles,
http://www.wolframalpha.com/input/?i=triangle+with+sides+(barcelona+to+paris),+(barcelona+to+rome),+(paris+to+rome) (136579 sq mi)
http://www.wolframalpha.com/input/?i=triangle+with+sides+(berlin+to+paris),+(berlin+to+rome),+(paris+to+rome) (178933 sq mi)
These triangle areas total to 315512 sq mi.
The disagreement maybe suggestive of not being coplanar, but maybe not conclusive.
http://www.wolframalpha.com/input/?i=distance+barcelona+to+paris (515.2 mi)
[not http://www.wolframalpha.com/input/?i=distance+barcelona+to+berlin (931mi) ]
http://www.wolframalpha.com/input/?i=distance+berlin+to+rome (735.5mi)
http://www.wolframalpha.com/input/?i=distance+rome+to+barcelona (535.5mi)
http://www.wolframalpha.com/input/?i=quadrilateral+with+edges+546,+515.2,+735.5,+535.5
[not http://www.wolframalpha.com/input/?i=quadrilateral+with+edges+546,+931,+735.5,+535.5
(gives the area as function of the two diagonals)
Interesting, but I don't have more time to play with this...
(EDIT: some corrections above... and now a little more...)
So the diagonals are
http://www.wolframalpha.com/input/?i=distance+paris+to+rome (689 mi)
Thus,
http://www.wolframalpha.com/input/?i=quadrilateral+with+edges+546,+515.2,+735.5,+535.5+with+diagonals+931,+689
gives an area of
312608 sq mi [presumably assuming that this quadrilateral with these edges and diagonals lie on a plane?].
If these cities were coplanar, this quadrilateral area 312608 sq mi
should be equal to the sum of the areas of the component triangles,
which gave 315153 sq mi and 315512 sq mi when decomposed two ways.
So, assuming that WolframAlpha is correct with its as-the-crow-flies-distances and area-calculations,
we can conclude that these cities are not coplanar.
(I'm too lazy to find a different way to check these numbers and this calculation.)
Another way to see this is to look at the angles. For any three cities you can take the distances and find a flat triangle that fits the distances. If you do that at Rome then you will find that the angle between Barcelona and Berlin is not equal to the sum of the angle between Barcelona and Paris and the angle between Paris and Berlin
Are you talking about on the paper or the actual angle?
In Weinberg's book there is a similar problem. But it is about the middle earth. Probably the only thing I like in that textbook.
This one's easier to see with a bigger triangle. Use the north pole and two points on the equator that are 90° apart. The distances are all equal and all three angles are right angles on the Earth. But the angles of an equilateral triangle on a Euclidean plane are not right angles. So the angles in a flat paper map do not match those seen on the surface of the Earth even though the distances do. The mismatch is smaller for smaller triangles, which is why we can get away with Euclidean geometry for small areas - like city maps.
https://en.wikipedia.org/wiki/Foucault_pendulum
To me, this is the most convincing proof not only that the Earth is not flat, but that it rotates as explained in the rotating spheroid model.
For me, it is more convincing, because it can be done in a single room and does not depend on outside sources of data that may be less reliable.
If that's not a slam dunk, the repeating the experiment at several latitudes should be.
The Earth as a rotating disc also explains Foucault's Pendulum.
How does the model of the flat Earth as a rotating disk explain the dependence of Foucault's Pendulum on latitude?
I am talking about the paper angle. There is no way to get the angles to match up on paper.
The actual angle will differ from the paper angle because the surface is not flat. So if you had the actual angle that would be another way to show that it is not flat. You could do that with the distances between three cities and anyone angle.
It doesn't, but then the argument that it is more convincing because it can be done in a single room no longer works.
(Edit: added from here)
And if you are going to travel a few hundred miles (North or South) you don't need anything as sophisticated as Foucault's Pendulum to see the Earth is not flat, just measure the shadow from a vertical stick at noon.
I corrected my WolframAlpha calculation and
concluded that the cities are not coplanar.
Would that really disprove the hypothesis of flatness? Could the Earth not still be flat with that experiment, but be angled with respect to the position of the sun at noon?
How would that give rise to a different length of shadow/angle of incidence at different latitudes? This is how Erastothenes calculated the circumference of the Earth.
It may be helpful to consider a simpler example. Suppose you have a square, 4 points, with the property that AB = BC = CD = AD, and equal diagonals ##AC = BD##.
Then if the four points are on a plane, we must have ## AC = \sqrt{2} AB##.
Suppose instead the 4 points are on a sphere. Then we have the surface notion of the distance ##AB_s## measured along the surface of the sphere, i.e. along a geodesic path (which will be a great circle), and a separate notion of the distance measured along a straight line in 3 dimensional space (a cuve that does not stay on the surface of the sphere, but goes underground). We will call this underground distance ##AB_u##, u for "underground". We can find the value of central angle ##\theta## subtended by the arc ##AB## and note that the ratio of the surface distance to the underground distance is depends on the size of the central angle subtended by the arc ##AB##, because ##AB_s / AB_u = r \theta / r \sin \theta = \theta / \sin \theta##.
We know that ##AC_u = \sqrt{2} AB_u##, as the 4 points lie on a plane in 3d space. We also know that the ratio ##AC_s / AC_u## is not equal to ##AB_s / AB_u## because the ratio depends on the central angle, and the central angle is different (it's larger for##AC## than for ##AB##). Thus we can conclude that ##AC_s## cannot be ##\sqrt{2} AB_s##.
I used the distances you provided to construct triangles of cities and calculate the interior angles of the quadrilateral. Adding up the eight half-angles (e.g. Barcelona-Rome-Paris) gets me a total of 359.6°, which a crude sensitivity analysis suggests is different from 360° if the error on the distances is less than plus or minus a mile.
I also did the same calculation summing the four full angles (e.g. Barcelona-Rome-Berlin). This time I got 360.4°. The difference from the Euclidean expectation is exactly the same as above (to three or four decimal places at least) but in the opposite direction.
Not sure if that symmetry is to be expected. I'm a bit surprised - does it look right to others?
Unfortunately, I again don't have time right now... But let me pose a related problem... Given the inter-city distances among those 4 cities, determine the radius of the earth.
Is 4 enough? Or do you need 5?
Only working vision will do that when there is an eclipse of the moon - the round Earth's shadow shape is very differnent from that a flat disk Earth would usually make and always the same no matter what time of day or night it is.
The ancient Greeks knew this. They also measured the diameter of the Earth by using the fact that twice each year at noon sunlight fell to the bottom of a deep well for a few seconds without hitting the sides. On that day at noon from a know distance due North, they measured the sun's angular difference from straight up. As I recall, they got the correct answer with less than 10% error. A feat not repeated for 1000 years! Their "clock" tell when noon was was the shortest length shaddow of a vertical stick.
After a few takes on this, I have the answer to Vanadium 50's question. My first intuition (finally confirmed) is that distance pairs between 4 points are sufficient to determine radius on the assumption that the points are on a 2-sphere. My reasoning started from part of an argument Synge uses to describe a 5 point curvature detector for spacetime. Part of his argument uses the Cayley-Menger determinant, specifically that this determinant being zero for 5 points is required for flatness of a Euclidean 3-space; and the deviation of this determinant from 0 gives some information about curvature. Reducing dimensions, a non-zero Cayley-Menger determinant for 4 points embedded in 2-surface must give some information about curvature. But if you assume constant curvature, there is only one one number needed, so 4 points should then be sufficient to determine the radius of curvature.
This is born out in the following reference (which initially confused by jumbling two related problems in one paragraph). Equation (3) in said reference, for our question, gives a formula for radius of a 2-sphere embedding 4 points in terms of their pairwise distances:
http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.104.4826&rep=rep1&type=pdf
