- 9,580
- 2,695
There is a physical notion of distance which implements the mathematical notion, and abstracts from any knowledge of the geometry (metric). Then it is valid to ask whether how a set of such measurements can give you information about the geometry.Mark Harder said:Nice. I think you've hit on the weakness in all the comments I've read so far. Namely, what do we mean by 'distance'? How would one know the 'distance'? By definition, the metric applicable to the Earth's surface is the contour length the great circle connecting any two cities. But this is a non-Euclidean geometry, a spherical geometry. (For one thing, the angles of a spherical triangle do not add up to 180 deg, which may play a role in our problem.) Therefore, the inconsistency between the distances defined by the spherical metric and the Euclidean distances is the result of the naive isomorphism between the 2 geometries. Perhaps there is a projection of the sphere onto the plane which preserves the distances between points on the two surfaces and the angles of triangles. I wouldn't know. But I do know what any 6th grader knows - that the Mercator projection is not the right one - all that business about Greenland being bigger than South America and so forth.
The physical notion is: take an ideal chain, fix it in e.g. Paris, extend it to Berlin, pull on it till it has no slack, then pull it to one place and measure it. The pulling till no slack implements the definition of geodesic as a distance minimizer.
