Venting a Propane Fridge in a Truck Campershell
In summary, the conversation discussed a solution to venting a propane fridge in a truck campershell window. The solution involved using flat cookie baking pans with holes and spacers to slow down the air and prevent propane from leaking into the camper. However, this solution may be dangerous and illegal due to transportation regulations and the need to close gas appliance tank valves while the vehicle is in motion. Some fridges designed for RV use have a 12 V DC power option for use while in motion.
bpcaddy
Just throwing some ideas togethor if anyone ones to comment!
Setup:
Propane fridge by truck campershell window
Problem:
Needs to vent
Drive on the road at 70 mph without blowing out
Not let propane into the cabin
Solution:
Several completely flat cookie baking pans with holes size of a pencil cut into them, offset holes from one pan to another of course to slow the air down because it has to change direction, and spacers between the pans maybe 2 quarters thick or thicker?
From the fridge to the campershell so propane won't leak into the camper...those disposable jiffy thick metal turkey roasting trays and
Glue?
Tape?
Caulking?
Something propane leak proof and maybe not permanent
Thread is closed. From a Mentor discussion about your posts:
Sounds dangerous and probably illegal. In most places there are Transportation of Dangerous Goods Regulations in place that prohibit such things. For RVs the regulations state that gas appliance tank valves must be closed when the RV is moving.
Some fridges designed for RV use have triple energy capabilities: mains power, gas, and 12 V DC. The 12 V DC is intended for use while in motion, powered by the towing vehicle.
Likes CalcNerd
Related to Venting a Propane Fridge in a Truck Campershell
What is venting a propane fridge in a truck campershell?
Venting a propane fridge in a truck campershell refers to the process of creating a safe and efficient ventilation system for a propane-powered refrigerator installed in a truck campershell. This is necessary to prevent the buildup of harmful gases, such as carbon monoxide, and to allow for proper combustion of propane gas.
Why is venting important for a propane fridge in a truck campershell?
Venting is important for a propane fridge in a truck campershell because it ensures the safety and functionality of the refrigerator. Without proper ventilation, there is a risk of carbon monoxide poisoning and poor combustion of propane gas, which can lead to inefficient cooling and potential fire hazards.
How do you vent a propane fridge in a truck campershell?
The process of venting a propane fridge in a truck campershell involves creating a venting system that allows for the release of gases and proper air circulation. This typically includes installing vents or fans in the campershell and ensuring that they are positioned correctly to allow for the flow of air. It is important to consult the fridge's manual or a professional for specific instructions.
What are the potential risks of not properly venting a propane fridge in a truck campershell?
The potential risks of not properly venting a propane fridge in a truck campershell include carbon monoxide poisoning, poor combustion of propane gas, and potential fire hazards. These risks can lead to serious health hazards and damage to the truck campershell and its contents.
Can I install a propane fridge in a truck campershell without venting?
No, it is not recommended to install a propane fridge in a truck campershell without proper venting. Ventilation is necessary for the safe and efficient operation of the fridge and to prevent potential health and safety hazards. It is important to follow the manufacturer's instructions and consult a professional for proper venting installation.
