Properties of limits of exponential functions
The discussion revolves around the properties of limits of exponential functions, particularly focusing on specific problems (P1, P4) related to these properties. Participants are exploring the implications of certain limit expressions and the assumptions underlying their proofs.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are questioning the use of natural logarithm properties in proofs and discussing the assumptions made in their reasoning. There are attempts to manipulate limit expressions to align with known limits, and some participants express uncertainty about specific problems.
The discussion is ongoing, with participants providing insights and raising questions about assumptions and details necessary for the proofs. Some guidance has been offered regarding the manipulation of limits, but there is no explicit consensus on the approaches being taken.
There are mentions of specific limits that are assumed to be valid, and participants are encouraged to clarify the conditions under which these limits hold. The discussion also highlights the importance of specifying whether constants involved are negative or non-negative.
A dummy progression
Prove the following properties (in pictures)
Using the def. Of natural logarithm
I did only the the first three prop.
And on a means we have, on pose or posons means let there be , propriétés means properties, alors meand then.
I apologize i am a french native speaker and i am busy so i cannot rewrite this in entirely english
I'm not convinced by what you have done for P1. Where did you use the properties of the natural logarithm?
In any case, you need to be clear about what you are assuming in your proof.
My guess is you are allowed to use
[tex] \lim _{x\to\infty} \left (1+\frac{1}{x} \right )^x = e\tag{1}.[/tex]
For P1, the above implies
[tex] \lim _{x\to\infty} \left (1+\frac{a}{x} \right )^x = e^{a}[/tex]
and therefore for any ##b\geqslant 0##
[tex] \lim _{x\to\infty} \left (1+\frac{a}{x} \right )^{bx} = e^{ba}.[/tex]
The others are done similarly. Your task is to manipulate the limit to look like (1).
Be careful with statements like if ##x\to 0##, then ##y:= \frac{a}{x}\to \infty\ (a>0)##. This is true assuming ##x\to 0+##. It's clear ##a,b## are some fixed constants, but specify whether they are negative/non-negative. These details are important.
I don't know how to do P4. But i proved all of the first three
On pose : we set , on a : we have , alors : then.
I didn't find P4 . Could you explain it to me?
What is assumed of ##u## and ##v##? Details are important! Do you seek to prove
[tex] \lim _{x\to a} u(x) ^{v(x)} = \exp \left ( \lim _{x\to a} (u(x)-1)v(x) \right )?[/tex]
If so, then don't bother, for this is false.
It is true that
[tex] \lim _{x\to a} u(x) ^{v(x)} = u(a) ^{v(a)}[/tex]
assuming ##u(x)^{v(x)}## is well defined around ##a## and ##u,v## are continuous at ##a##.
  • · Replies 0 ·
9K
