Properties of Systems: Memoryless, Causal, time invariant, linear
1 reply · 16K views · last reply
itsdinamo
Hi, I need a hand with my reasoning on the following question.
I have answered all the questions, but not too sure weather they are correct.
Please guide me or point me on the right direction if they are not correct.
Regards
1. A system defined by the following equation y(t)=[x(t-2)]^2
Is the system Memoryless, Causal, Time Invariant, linear
The attempt at a solution
Memoryless ?
y(t)=x(t-2) has memory, the output is equal to the input two seconds ago.
y(t)=[x(t)]^2 = memoryless, the output at time t0 depends only on the input value at time t0.
Now, y(t)=[x(t-2)]^2 can be thought as y(t)=[x(t-2)*x(t-2)] right?, if so, my best guess would be that the system y(t)=[x(t-2)]^2 has memory.
Causal?
by definition; A system is causal if the output at any time t0 is dependent on the input only for t<=t0.
y(t)=[x(t-2)]^2 = causal
Time Invariant?
by definition if
x(t)--->y(t), then
x(t-t0)--->y(t-t0)
so;
x(t-t0)--->[x((t-t0)-2)]^2
y(t-t0)=[x((t-t0)-2)]^2,
Therefore, y(t)=[x(t-2)]^2 is time invariant.
linear ?
A system is linear if it is homogeneous and additive.
Homogeneous Property
if x(t)--->y(t), then
ax(t)--->ay(t) a= alpha
Additive Property
if x1(t)--->y1(t), and x2(t)--->y2(t), then
x1(t)+x2(t)--->y1(t)+y2(t),
x(t)--->y(t)=[x(t-2)]^2
multiply input by alpha a, then
ax(t)--->[ax(t-2)]^2
ay(t)--->a[(x(t-2))^2]
system y(t)=[x(t-2)]^2 is not homogeneous, thus not linear.
Looks good. On the last one, it would be a little clearer if you explicitly pointed out ##\alpha x(t) \Rightarrow [\alpha x(t-2)]^2 = \alpha^2 [x(t-2)]^2 \ne \alpha [x(t-2)]^2 = \alpha y(t).##
