Proportional plus derivative controller
Jason-Li
FIGURE 6 shows a proportional plus derivative controller that has a proportional band of 20% and a derivative action time of 0.1 minutes. Construct the shape of the output waveform for the triangular input waveform shown, if the input rises and falls at the rate of 4 units per minute.
None required
Hello,
There is a thread related to this question however it was marked correct but doesn't look correct to me?
https://www.physicsforums.com/threads/step-change-in-a-proportional-plus-integral-controller.961180/
I think I have it but it is quite different to other answers I have seen?
I have found
PB=20% hence gain=5
dAT = 0.1min = 6s
Would rise and peak at 2units at 30s however due to gain this will be 10units, hence change due to derivative would be:
10/30 * 6s = 2units, then once peaked at 30s it would reduce by the same derivative and create the following graph:
spoto2 said:
Find out information about proportional-plus-derivative control. Control in which the control signal is a linear combination of the error signal and its derivative.
Can you post some links to such information that would be helpful for the Original Poster (OP)? Thanks.
Tromso80 said:
Hi Jason, Just wondered what your maths is behind this?
The maths is in the first post, which part are you unsure of?
