Proton velocity(magnitude and direction)
  • Thread starter Thread starter jason shaw
    Direction Proton
4 replies · 2K views
jason shaw
A proton enters a region in which there is a magnetic field B=0.2T pointing along the positive z axis,and an electric field E=7.4 N/C pointing along the positive y axis. If we want the proton to continue traveling in a straight line without changing speed,what should its velocity(magnitude and direction) be?
Welcome to PF;
The way to get the most out of this forum is to show us your attempt at the problem - otherwise the best we can manage is to point you at some theory that will no doubt also be in your notes.
I am really confused with this problem and really don't know where to start. Do I figure the two forces separate first? Also ,I wouldn't think the proton is going to go in a straight line.
Spinnor gave you a reference to look at - that should help.
You have a situation where there are two forces acting on an object - you know how to handle this: do a free-body diagram. Draw an arrow for the force from the B field, use that to work out which direction the force from the E field should point ... from that you can use Newton's laws to work out the magnitude.
