Prove a limit exists and evaluate it
  • Thread starter Thread starter james.farrow
    Limit
The limit to evaluate is lim x-> 0 (1 - cos(2x))/(x^3 + 4x^2). Using l'Hôpital's rule, the derivatives of the numerator and denominator both yield zero at x=0, leading to the second derivatives f''(0) = 4 and g''(0) = 8. The limit is determined to be f''(0)/g''(0), which simplifies to 4/8 or 1/2. There is a discussion about the application of l'Hôpital's rule, clarifying that it can be applied multiple times in cases of the indeterminate form 0/0. The conclusion is that the limit exists and equals 1/2.
james.farrow
We are required to find
lim x-> 0 1- cos(2x)/x^3 + 4x^2
Let f(x) = 1 - cos(2x) & g(x) = x^3 + 4x^2
f'(x) = 2sin(2x) so f'(0)=0
g'(x) = 3x^2 + 8x & g'(0) = 0
so by l'Hopitals rule
lim x -> 0 2sin2x/3x^2 + 8x if it exists
Now
f''(x) = 2(2cos2x) & g''(x) = 6x + 8 = 2(3x + 4)
But f''(0) = 4 and g''(0) = 8
Shouldn't f''(0) = g''(0) = 0 here?
I'm a little bit stuck now?
or is the limit just f''(0)/g''(0) which is 4/8 which is a half?
Many thanks
James
Mathematics news on Phys.org
The limit is f''(0)/g''(0), and it is 4/8=1/2.
If f"(0)/g''(0)=0/0, then the limit will go to infinity, hence no limit will exist.
Regards.
You could use the power series of the cosine.
Regards.
BTW that is simply not true. You can keep applying L'Hoptials rule as many times as you like, while ever you are faced with 0/0. Take for example x^4 / ( 1-cos x )^2, you'd need to go to the 4th derivative in this case before L'Hopitial's finally cracks it.
Cheers everyone I think I'm getting the hang of it...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
