LHS = (p+1)^2 + (p+1) = p^2 +2p +1RHS= 2^(p+1) = 2^p *2 = 2(p^2 + p)
  • Thread starter Thread starter Firben
    Induction
The discussion focuses on proving by induction that n^2 + n ≤ 2^n for all integers n≥5. The initial cases demonstrate that for n=5, the left-hand side (LHS) is less than or equal to the right-hand side (RHS). The next step involves assuming the statement holds for n=p and then proving it for n=p+1. Participants emphasize the importance of correctly applying the induction hypothesis to simplify the expression for LHS(p+1). The conversation highlights the need to clearly articulate the assumption that the formula holds for n=p to proceed with the proof.
Firben
Prove by induction that n^2 + n ≤ 2^n
How i did:
Case(1)
Suppose that n = 5
LHS = 5^2 +5 = 30
RHS = 2^5 = 32
30 ≤ 32
Ok LHS ≤ RHS
Case (2)
Suppose that's true for n=p≥5. Show that its true for n = p+1
What should i do next ? I had a memory loss here :(
Just write down (p+1)^2+(p+1) and work with that expression until you see that it's \leq 2^{p+1}. You will have to use the assumption p^2+p\leq 2^p.
LHS(p+1) = (p+1)^2 + p+1 = p^2 + 2p + 1 + p + 1 = p^2 +3p + 2
How can i continue ?
Well, what's your assumption?
Yes, i think so
No, he asked "what's your assumption?", and you were supposed to answer "that the formula I want to prove for all n≥5 holds when n=p".
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
