Prove Inequality: x,y,z - Solution Needed
  • Thread starter Thread starter JennyPA
    Inequality
The discussion centers on proving the inequality involving three variables x, y, and z, constrained by the conditions x+y+z=1 and 0<x,y,z<1. Participants express uncertainty about whether the maximum occurs at x=y=z=1/3 and emphasize that proving this for all combinations of x, y, and z is necessary for completeness. There are suggestions to utilize calculus methods like Lagrange multipliers to find the maximum, but some participants note that calculus is not permitted for this problem. Algebraic manipulations are discussed, particularly how to eliminate one variable to simplify the expression. The conversation highlights the need for a rigorous proof rather than relying on specific examples.
JennyPA
I found this problem the other day, seems interesting but I am still not sure about the solution
Anybody can help
x, y, z are numbers with
prove that
sqrt(xy/(z+xy))+sqrt(yz/(x+yz))+sqrt(xz/(y+xz))<=3/2 ("<=" means less or equal)
Mathematics news on Phys.org
I haven't worked it through. However, it looks like the max is assumed when x=y=z=1/3. In that case each term in the sum = 1/2.
You are right I did that part already and think it's not enough
What do you mean, it is not enough?? Why do you think that??
It should be proved for all other combinations of x,y and z.
Proving only for x,y and z equal 1/3 is incomplete
But the expression reaches a maximum when x=y=z=1/3, so doesn't that tell you anything?
micromass said:
** But the expression reaches a maximum when x=y=z=1/3, so doesn't that tell you anything?
Devil's Advocate:
** You claim that the maximum is reached when x = y = z = 1/3, but
it has not been shown by anyone in this thread that it is (or referenced to
another place as already known to be).
So . . . . . I am not convinced that the expression could not be greater than 3/2.
mathman stated that "it looks like the max..." <---- Not concrete
When JennyPA stated that she "did that part already" in response
to mathman, she may have just referred to plugging in 1/3 for each
variable to see that particular sum is 3/2 , but had no knowledge of
whether that selection makes a maximum or not.
I suggest that someone use some elementary calculus and see of the max is where it appears to be. To avoid partial derivatives, hold x constant and see if the max is at y=z. If that works, the rest should be easy enough.
There was a previous discussion on this forum about this hypothesis:
If f(x,y,z) is continuous and symmetric, that is, f(x,y,z) = f(y,z,x) = f(z,x,y), then if that function has a global maximum at f(x*,y*,z*), then x*=y*=z*
That discussion didn't include a proof of that, though.
IIRC it was a function had to have a unique global maximum.
Good point: if it's unique, then obviously x*=y*=z*
Just a little algebra and the each term can eliminate a variable: xy/(z + xy) = xy/[(1-x)(1-y)]
Likewise for the other 2 terms.
I am still working on this problem and has no clue how to proceed from here.
The best suggestion kind of got lost in the noise here. Take derivatives and use Lagrange multipliers/whatever calculus method you feel most comfortable with to find the maximum of the function
The problem is I am not suppose to use calculus for this problem. This is the algebra course
xy/[(1-x)(1-y)] when you eliminate z, then this expression is always 1 when x+y = 1
how you eliminate z?
you can replace z with 1-x-y but can't see what you did
That's what I did, Then 1-x-y+xy =(1-x)(1-y)
I understand that part I did that but can't get the statement x+y=1
since z is no longer a part of this term, I looked at values for x and y to see where the max for the term is. The restrictions of x + y + z = 1 then x + y can't exceed 1.
