Prove limit of this recursive sequence
  • Thread starter Thread starter vrbke1007kkr
    Limit Sequence
7 replies · 9K views
vrbke1007kkr
Let s1=1 and for n>=1 let sn+1=sqrt(sn+1)
Prove that the limit of this sequence is 1/2(1+Sqrt(5))
Show that there exist an N for every [tex]\epsilon[/tex]> 0, such that n>N implies
|Sn-1/2(1+Sqrt(5))|< [tex]\epsilon[/tex]
I can prove that s is a increasing sequence bounded above thus s converges to a real number, but how to manipulate the terms inside the absolutely value takes a little more than conventional wisdom.
At first we realize that: sn+12 = sn+1, and since we are dealing with an increasing sequence, we can find a bound for sn, but can't see how that's useful
thanks, seems exactly what I needed. To reach that conclusion, can I take the following steps:
Let lim sn = s
Since lim (An + Bn)= lim An + lim Bn then lim (Sn + 1) = s + 1
Then use an similar argument for the square root to obtain lim sn+1 = Sqrt(s + 1)
and since lim sn = lim sn+1, s = sqrt(s+1)
Let lim sn = s
Sure. Taking the limit of s_n+1=sqrt(sn+1) gives you L=sqrt(L+1).
If this is for a real analysis course you should probably justify that such a limit must satisfy this equation by mentioning the fact that sqrt(x) is continuous. This is the 'similar' argument you are thinking of when you look at the inference "lim (An + Bn)= lim An + lim Bn then lim (Sn + 1) = s + 1".
sqrt(x) and x+1 are continuous.
Thanks :) good thing we already proved the latter in a previous theorem so we can use it freely
Try using the quadratic equation to get your limit. :-)
Equivalently, show that your limit is the root of the equation x^2 - x -1.
I do not think continuity is need here. These results are simple limit theorems. Besides, continuity usually comes after limit of sequences so I doubt it should be used here.
