Prove Riemann Sum: (ex-1)/x for x > 0
The discussion revolves around proving the limit of a Riemann sum involving the expression (e^x - 1)/x for x > 0. The original poster presents a limit involving a summation and expresses uncertainty about connecting this to the integral that yields the desired result.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the connection between the summation and the integral, with some suggesting the use of geometric series to simplify the summation. Others discuss the application of L'Hôpital's rule to evaluate limits arising from the expressions.
Participants are actively engaging with the problem, offering insights and corrections. Some have provided guidance on applying mathematical techniques, while others are working through their reasoning and calculations. There is a collaborative effort to clarify misunderstandings and refine approaches.
There is mention of a hint from the original poster's professor regarding Riemann sums, suggesting that the problem may require deeper exploration of this concept. Additionally, participants note the importance of correctly identifying and handling limits and derivatives in their calculations.
PiRGood
Prove that:
lim n->inf1/n*Ʃn-1k=0ekx/n
(ex-1)/x
x>0
That was all the information provided. Any progress i have made is below. I didn't want to add any of that to this section because this is all speculation on my part so far.
I've been at this for awhile now, i feel as though i am getting close. I think i have all the "pieces" but i can't seem to put them together to prove the above statement.
I know that the integral
01etxdt is important because it integrates to
(ex-1)/x
but I'm not sure how to connect the summation to the integral to the answer
I also have a feeling that the Theorem
Suppose that f is defined on [a,b] and that lim||P||->0Rp(f) exists. Then f is integrable on [a,b] and
abf = lim||P||->0Rp(f)
is relevant. But I'm not positive.
Any help would be extremely appreciated!
The thing your really need to notice to evaluate that sum is that e^(kx/n) is a geometric series. It's r^k where r=e^(x/n). There is a formula to sum a geometric series. Then, sure, your theorem tells you the limit as n->infinity of the sum is the integral. So now after you've simplified the sum try to find the limit.
If i recall correctly that formula is
1-rn/ 1-r
I tried that but i hit a roadblock. I came up with 1-exn/n/ 1-ex/n. You can cancel the n's in the numerator's exponent of course. But that is where i hit my dead end. I couldn't manipulate it from there in any meaningful way, even using the 1/n factor in front of the summation.
The reason i abandoned that course is because my professor hinted that i should look in the chapter of my book regarding Riemann Sums. But I've yet to dig up anything useful besides the Theorem i quoted in the OP
PiRGood said:
If i recall correctly that formula isI tried that but i hit a roadblock. I came up with 1-exn/n/ 1-ex/n. You can cancel the n's in the numerator's exponent of course. But that is where i hit my dead end. I couldn't manipulate it from there in any meaningful way, even using the 1/n factor in front of the summation.
That's a good start! So you've got a 1-e^x part. Now look at the denominator, lim n*(1-e^(x/n)) as n->infinity. That's an infinity*0 form, right? That suggests you might want to write it as (1-e^(x/n))/(1/n). That's a 0/0 form and you can apply l'Hopital's rule.
But wouldn't taking the derivative of 1/n give us zero, because n is some constant approaching inf? So the derivative of (1-e^(x/n)) would be (xe^(x/n))/n and the derivative of 1/n would be 0, giving me ((xe^(x/n))/n )/0?
Well, no. n isn't constant. It's a variable approaching infinity. x is the constant while you are taking the limit. You want to take d/dn of the numerator and denominator.
So i am are applying L'Hôpital's rule to the fraction in the denominator of our function i.e applying it to (1-e^(x/n))/(1/n)
So i get -xe^(x/n)/(n^2) on top and -1/n^2 on the bottom which simplifies to:
xe^(x/n)?
xe^(x/n)?
You missed a minus sign. But otherwise ok! Now take limit n->infinity of x*e^(x/n).
as n approaches infinity x/n approaches zero, which means e^(x/n) approaches one which leaves me with x on the bottom!
Incredible, i never would have seen that. Thanks so much Dick! You are a lifesaver!
Yeah, it does work out nicely and you are welcome. But so far you've got (1-e^x)/x, and you want to get (e^x-1)/x. Better find that lost minus sign before you call it a done deal.
