Prove that [a/b]+[2a/b]+....+[(b-1)a/b]=(a-1)(b-1)/2
5 replies · 4K views
Titan97
Prove that $$\sum_{r=1}^{b-1}[\frac{ra}{b}]=\frac{(a-1)(b-1)}{2}$$ where [.] denotes greatest integer function and a & b have no common factors.
##n\le [n]<n+1##
<x> denotes fractional part of x.
3. The Attempt at a Solution
I first added and subtracted ##a/b + 2a/b +3a/b +...+(b-1)a/b## to get:
$$\frac{a(b-1)}2-\sum_{r=1}^{b-1}<\frac{ra}{b}>$$ where <.> denotes fractional part. This way I got closer to the answer. Also, <x> is a periodic function and it would be better to convert [.] to <.>. But I am stuck at this step.
on Phys.org
It can be interesting to have a look at
$$\sum_{r=1}^{b-1}<\frac{ra}{b}> + \sum_{r=1}^{b-1}<\frac{b-ra}{b}>$$
##\frac{b-ra}{b}=1-\frac{ra}{b}##.
The sum will be b-1
That solves the problem. But how did you do that post #2 magic? Did it pop in your mind when you saw the question? Or have you come across problems like these before? Is it because of practice?
The sum runs over all remainders of n/b, and it does so in a symmetric way.
That trick is not so uncommon.
