Prove that every integer n>= 14 is a sum of 3's and/ or 8's.
  • Thread starter Thread starter snaidu228
    Integer Sum
To prove that every integer n ≥ 14 can be expressed as a sum of 3's and/or 8's, one must demonstrate that n can be represented in the form n = 3a + 8b, where a and b are non-negative integers. The base case shows that 14 can be expressed as 3 + 3 + 8, confirming the hypothesis for n = 14. It is essential to consider adjacent integers, n-1 and n+1, to establish a pattern or recurrence that ensures non-negative solutions for all integers greater than or equal to 14. Induction may not be the most effective method for this proof; starting with multiples of 3 provides a clearer approach. Ultimately, the goal is to find at least one non-negative solution for each integer n ≥ 14.
snaidu228
Induction Hypothesis
Base Case: P(0):
Suppose n= 14, and k is an integer representing number of times 3 or 8 is added:
14= 3k;
k=14/3 ( this shows that 14 is not a sum of 3's)
But the question says to show that. I'm confused on how to show that.
14= 3+3+8
it's and/or
You need to be able to show that every number >= 14 is a linear combination of 3s and 8s. IOW, that n = 3a + 8b for some integer values of a and b, with a >= 0, b >= 0. (I don't think that either a or b can be negative, but either one could be zero.)
That's what you need to show, but I don't have any idea right now of how to go about doing this.
That parenthetical remark is essential. Consider n=13. This has solutions for a,b in the integers. For example, a,b = -1,2 and 7,-1 are both solutions to 3a+8b=13. In fact, given any integer n, there are an infinite number of solutions a,b in Z such that 3a+8b=n. So the problem is to not only show that integer solutions a,b exist but also to show that at least one such solution has both a and b non-negative.
BTW, induction might not be the best choice here. Start with multiples of 3, n=3m. This obviously has a,b=m,0 as one solution to 3a+8b=n, and this a,b is in the non-negative integers if n is non-negative. What can you say about the two adjacent integers, n-1 and n+1?
