Prove that the gradient is zero at a local minimum.
To prove that the gradient is zero at a local minimum, consider a function F with first-order partial derivatives, where x is a local minimizer. The condition states that F(x + h) is greater than or equal to F(x) for small perturbations h. By defining a one-dimensional function g(t) = F(x + t e_i) and recognizing that g has a local minimum at t = 0, it follows that g'(0) must equal zero. This leads to the conclusion that the limit of the difference quotient, which represents the partial derivatives, is also zero, thus confirming that the gradient ∇F(x) = 0 at the local minimum. The discussion highlights the importance of using one-dimensional analysis to simplify the proof.
Bosley
Suppose F: Rn --> R has first order partial derivatives and that x in Rn is a local minimizer of F, that is, there exists an r>0 such that
f(x+h) \geq f(x) if dist(x, x+h) < r. Prove that
\nabla f(x)=0.
We want to show that fxi(x) =0 for i = 1,...,n
So we want to show that \lim_{t\to 0}\frac{f(x + t e_i) - f(x)}{t} = 0
Where e_i is the ith standard basis element.
We know f(x+h) \geq f(x) if ||(x+h) - x|| <r, that is, if ||h|| < r.
Consider |t| < r. Then ||t ei|| = |t| < r.
So then f(x) \leq f(x + t ei) for all t such that |t| < r, and f(x+t ei) - f(x) \geq 0.
But I don't know where to go from here...insight?
There may be a better way of doing this. In particular, let \hat x \in\mathbb R^n be your minimum. Define the function g: \mathbb R\to \mathbb R by g(t) = F(\hat x+te_i ).
What can you say about the minima of g? How does this help you?
Well, the minima of g would occur where
<br /> g&#039;(t) = \frac{dF}{dt}(\hat{x} + t e_i) = 0 I suppose, but I'm not sure how to employ that. Can you give me a little more of a hint? I'm not seeing what we can say about the derivative of F with respect to t, I guess.
Well, the minimum of F is \hat x right? So any other value of x would give F(x) \geq F(\hat x). In particular, what if we set x = \hat x + t e_i?
If that's still too esoteric, what happens to g(t) when we let t=0? What happens when t \neq 0?
Hmm...your post disappeared?
My tex code got screwed up and then I had to step away from the computer so I deleted it. Anyway:
g(0) = f(\hat{x})
g(t) = f(\hat{x} + t e_i) where t \neq 0
So g(t) \geq g(0) for all t.
But how is this different from what I originally had, which is that f(x + te_i) \geq f(x)? I'm sorry I'm having so much trouble putting together your hint.
It's okay.
The point here is that g has a minimum at 0. So in particular you can show very easily that \left. \frac d{dt} \right|_{t=0} g(t) = 0 [/tex], since this is only one dimensional right? I&#039;m not sure if you&#039;re allowed to assume this, but it&#039;s fairly easy to prove and you don&#039;t need to use vectors.<br /> <br /> Now try finding g&#039;(0) in terms of F.
Aha. I think I get it. Is this what you were getting at (note, I have slightly altered the notation):
Assume x is a local minimum of f.
Define g(h) = f(x + h e_i) considering small values of h (so that |h| < r)
Note that g(0) = f(x). So,
g(0) \leq g(h) \forall |h| &lt; r
That is, g has a local minimum at h = 0.
Since g is a function in one variable, we know that g'(0) = 0 since g has a local min at 0.
Then, <br /> g&#039;(h) = \lim_{t \to 0}\frac{g(h+t) - g(h)}{t} \\<br /> g&#039;(h) = \lim_{t\to 0} \frac{f(x+(h+t) e_i) - f(x+h e_i)}{t}
Since we know g'(0) = 0, plugging in h = 0 we get:
0 = \lim_{t\to0}\frac{f(x + t e_i) - f(x)}{t}, which is what we wanted to show.
eh?
(p.s. Thank you so much for your helpful hints.)
  • · Replies 105 ·
