Prove the intersection of two orthogonal subspaces is {0}
The discussion centers on proving that the intersection of two orthogonal subspaces A and B in an inner product space V is solely the zero vector, {0}. The initial proof attempt involved two cases, but it was suggested that a proof by contradiction would be more effective, demonstrating that if a vector exists in both A and B, it must be the zero vector. Clarification was provided that while A and B are orthogonal, this does not imply that A equals the orthogonal complement of B. The conversation highlights the importance of clear reasoning in mathematical proofs and the need for thorough justification of each step. Overall, the conclusion reached is that A ∩ B = {0}.
SithsNGiggles
Let A and B be two orthogonal subspaces of an inner product space V. Prove that A\cap B= \{ 0\}.
I broke down my proof into two cases:
Let a\in A, b\in B.
Case 1: Suppose a=b. Then \left\langle a,b \right\rangle = \left\langle a,a \right\rangle = 0, which implies a=b=0. Thus 0 \in A\cap B.
Case 2: Suppose a \not= b. Then b \not\in A \wedge a \not\in B, so a,b \not\in A \cap B. This implies A \cap B = \emptyset.
Therefore A\cap B = \{ 0\}.My main question is if my second case works. It took me quite some time to convince myself that it was, but now I'm doubting myself again. Thanks
No, it doesn't work—at least, not without more explanation. Try a proof by contradiction for this step: assume ##b \in A##, see what that implies. Then do the same for ##a \in B##. Together, these conclusions will contradict ##a \not= b##.
Generally speaking, if you need to think very hard to convince yourself that a step in your proof is correct, then your proof isn't complete. All the convincing should be done on the page.
Very well said!
Yeah, I considered doing a proof by contradiction, but the way I did it involved (essentially) the same "logic" I used in the first case of what I posted earlier.
Here goes:
Case 2: Suppose ##a\not =b##.
Let ##b \in A##. Then, ##b \bot b \Rightarrow \left\langle b,b \right\rangle = 0 \Rightarrow b = 0##.
Let ##a \in B##. Then, ##a = 0## by similar reasoning.
Thus ##a = b##, contradicting the assumption. Therefore ##A \cap B = \{ 0 \}##
Thanks for the tip.
I also have a slightly irrelevant question. Since ##A## and ##B## are orthogonal sets, does that necessarily mean that ##A = B^{\bot}## (orthogonal complement)? Just wondering. The definitions my professor provided weren't quite clear on this.
Here goes:
Thanks for the tip.
You really don't need to split into cases or choose two vectors. Choose one vector a that is in AnB. Since a is in A and a is in B a must be perpendicular to a. So a=0 using your argument. And no, in three dimensional space the x-axis is perpendicular to the y-axis, but the orthogonal complement of the x-axis is the y-z plane. A is a subset of the orthogonal complement of B, but it's not necessarily equal to it.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
