Prove the sum of two subspaces is also a subspace.
The discussion focuses on proving that the sum of two subspaces, U and W, is also a subspace. It emphasizes that both U and W contain the additive identity and are closed under scalar multiplication, which implies that their sum U + W also contains the additive identity and is closed under scalar multiplication. Participants suggest clarifying the justification for closure under addition by demonstrating that any sum of elements from U and W remains within U + W. The conversation highlights the importance of explicitly showing how the properties of U and W apply to U + W. Overall, the thread provides guidance on structuring the proof effectively.
PhillipKP
Hi I'm trying to prove that the sum of two subspaces U and W is also a subspace.
U is a subspace of V if U is also a vector space and it contains the additive identity, is closed under addition, and closed under scalar multiplication.
The definition of a sum a vector subspace U and W is
U+W=\{u+w:\, u\in U,w\in W\}
1. Since U and W both contain the additive identity, U+W contains the additive identity
3. Since both U and W are closed under scalar multiplication, any combination of u+w is closed under scalar multiplication since multiplication is distributive, associative and commutes (assuming were dealing with the reals here). I'm having a hard time thinking about how to justify that U+W is closed under addition.
Also is my justification for closure under scalar multiplication right?
First let Z = U+W
to show its closed under addition
so take z, z' in Z then show z + z' is an element of Z
your words are close, but I would try a similar thiong for the scalar multiplication to be a little more explicit
Writing this means that: U + W is the set of the sum of all possible 2 vectors, of which one is taken out from U, and the other from W, i.e:
  • If u is some vector of U, and w is some vector of W, then u + w \in U + W. (1)
  • And if v is some vector of U + W, then it can be split into the sum of 2 vectors, one in U, and one in W. That is: v \in U + W \Rightarrow \exists u \in U, w \in W : v = u + w[/itex] <b>(2)</b>.<br />
<br /> <br /> <blockquote data-attributes="" data-quote="PhillipKP" data-source="post: 2337030" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> PhillipKP said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> <h2>The Attempt at a Solution</h2><br /> <br /> 1. Since U and W both contain the additive identity, U+W contains the additive identity </div> </div> </blockquote><br /> Ok, this is good, but you really need to <b>show</b> why it contains the additive identity, instead of just reasoning like that. You can go like this:<br /> <br /> Since U, and W are subspaces, that means:<br /> <br /> \left\{ \begin{array}{c} 0 \in U \\ 0 \in W \end{array} \right. \Rightarrow 0 = 0 + 0 \in U + V <u>(due to <b>(1)</b>)</u> (the underline part is just for you to understand why)<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> 3. Since both U and W are closed under scalar multiplication, any combination of u+w is closed under scalar multiplication since multiplication is distributive, associative and commutes (assuming were dealing with the reals here). </div> </div> </blockquote><br /> As I said above, you should make this part clearer.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I&#039;m having a hard time thinking about how to justify that U+W is closed under addition. </div> </div> </blockquote><br /> Just start out as normal. So, what you want is to prove that:<br /> <br /> \forall v_1 \in U + W, v_2 \in U + W, we must have v_1 + v_2 \in U + W<br /> <br /> Hint: Use <b>(2)</b>, and the fact that both U, and W are already subspaces. :)<br /> <br /> The same proof goes for &quot;<i>closed under scalar multiplication</i>&quot;.
Ok thank you. Let me think about this some and try to make some progress. I'll be back later in the day.
OK I think I got it. Thanks guys!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 61 ·
