Proving a Limit Involving Integrals and a Locally Integrable Function
13 replies · 2K views
MatthewD
Suppose [tex]f[/tex] is continuous and [tex]F(x)=\int_a^x f(t)dt[/tex] bounded on [tex][a,b)[/tex]. Given [tex]g>0, g'\geq 0[/tex] and [tex]g'[/tex] locally integrable on [tex][a,b)[/tex] and [tex]lim_{ x\rightarrow b^-} g(x) =[/tex] infinity. prove
for p>1
[tex]\displaystyle{lim_{ x\rightarrow b^-} \frac{1}{[g(x)]^p} \int^x_a f(t)g(t)dt = 0}[/tex]
If you know [tex]lim_{ x\rightarrow b^-} g(x) =\infty[/tex], don't you also know [tex]lim_{ x\rightarrow b^-} \frac{1}{[g(x)]} = 0[/tex] and therefore [tex]lim_{ x\rightarrow b^-} \frac{1}{[g(x)]^p}=0[/tex]...so we're done? But the hint says to use parts so I don't know :(
Any help would be greatly appreciated
thats only the case if the integral is bounded, so you should try & show that...
How would I show an integral is bounded? If I know obviously [tex]\int_a^x f(t)dt[/tex] is bounded, how would I know anything about the g function. The information given basically denies that its bounded right? Since the limit is infinity? I'm so lost!
also, bounded would show it, but I think a lesser constraiint may also work, either way I would try simplifying things by using integration by parts
When I tried parts, i let u= g(t) and dv = f(t)dt so du = g'(t)dt and v = F(t) and I got
[tex]\displaystyle{lim_{ x\rightarrow b^-} \frac{1}{[g(x)]^p} \int^x_a f(t)g(t)dt = lim_{ x\rightarrow b^-} \frac{1}{[g(x)]^p} (g(x)F(x) -g(a)F(a)- \int^x_a F(t)g'(t)dt)}[/tex]
[tex]\displaystyle{= lim_{ x\rightarrow b^-} \frac{1}{[g(x)]^p} (g(x)F(x) - \int^x_a F(t)g'(t)dt)}[/tex]
since F(a) = 0
Can I reduce further...?
i see it now, using parts helped a lot, thanks
i'm suppose to follow it up with this addition:
assume further that [tex]\int^b_a f(t)dt[/tex] converges and show [tex]lim_{x \rightarrow b^-} \frac{1}{g(x)} \int_a^x f(t)g(t)dt = 0[/tex]
i used parts again and came down to the fact:
[tex]lim_{x \rightarrow b^-} \frac{1}{g(x)} \int_a^x f(t)g(t)dt = lim_{x \rightarrow b^-} \frac{1}{g(x)} \int_a^x F(t)g'(t)dt[/tex]
how do i show, for sure, this =0?
how about usng the fact that F is bounded, g'>0 and setting up an inequality which squeezes your expression to zero?
The entire expression, or just the integral part? Could I do:
[tex]lim_{x\rightarrow b^-} \frac{1}{g(x)} \leq lim_{x\rightarrow b^-} \frac{1}{g(x)} \int^x_a F(t)g'(t)dt \leq lim_{x\rightarrow b^-} \int^x_a M g'(t)dt[/tex]
where the right hand side becomes
[tex]=lim_{x\rightarrow b^-} \frac{1}{g(x)}M(g(x)-g(a))[/tex]
[tex]=lim_{x\rightarrow b^-} M(1-\frac{g(a)}{g(x)})[/tex]
But how does this squeeze to 0? or am i looking at it wrong?
the 2nd half of the equality is looking good, but i think you dropped a factor of p somewhere, maybe you could assume [itex]p = 1+\epsilon, \epsilon>0[/itex]
you may need to tighten it up by accounting for the case when M<0, ie by starting from [itex]\exists M > 0 : |F(x)|<M,\forall x \in [a,b)[/itex]
but there's no p in the second part of the problem...?
This is the second part...
ok sorry, i missed the 2nd part, so you're ok with the first bit now?
so if i integrate by parts I get a little different:
[tex]\lim_{x \to b^-} \frac{1}{g(x)}\int_a^x dt f(t)g(t)[/tex]
[tex]= \lim_{x \to b^-}\frac{1}{g(x)}(F(t)g(t)|_a^x - \int_a^x dt F(t)g'(t))[/tex]
[tex]= \lim_{x \to b^-}(F(x)-\frac{F(a)g(a)}{g(x)} - \frac{1}{g(x)}\int_a^x dt F(t)g'(t))[/tex]
using convergence of F as x->b, then
[tex]= F(b) - \lim_{x \to b^-}\frac{1}{g(x)}\int_a^x dt F(t)g'(t)[/tex]
so working this line, i guess you need to try & show the limit of the end expression is F(b)...
i haven't totally worked it out, but it may help to try and show for any a<x0<b
[tex]\lim_{x \to b^-}\frac{1}{g(x)}\int_a^{x_0} dt F(t)g'(t) = 0[/tex]
noting that as g' is locally integrable, it means g is defined on the interval [a,b), ie. it doesn't explode anywhere
then try splitting the integral into separate portions & considering the continuity of the function f on a small region near to b. (though i could see this might get tricky with double limits...)
