Proving Absolute Convergence of a Recursive Sequence
  • Thread starter Thread starter wany
    Convergence
6 replies · 2K views
wany
Given the recursive sequence: [itex]a_k=(-1)^k(1+k\sin(\frac{1}{k}))^{-1}a_{k-1}, k>1[/itex] with [itex]a_1=1[/itex]. Prove that [itex]\displaystyle\sum\limits_{k=1}^{\infty} a_k[/itex] converges absolutely.
ratio test, l'hospital's rule
So I know how to do this problem using the approximation of sine, but we cannot use that.
So I use the ratio test to get [itex]\mathop {\lim }\limits_{k \to \infty } |\frac{1}{1+(k+1)\sin(\frac{1}{k+1})}|[/itex]
Then I use l'hopital's rule several times and get it down to:
[itex]\frac{-cos(\frac{1}{k+1})}{k+1}[/itex]
So taking the limit as k goes to infinity of this, I know that cos is bounded by -1,1 and 1/(k+1) goes to 0, so this would go to 0.
So since 0 < 1, we can say that this series converges absolutely by the ratio test.
I don't see where you applied l'hopital on this limit:
[tex]\lim_{k \rightarrow \infty } \left|\frac{1}{1+(k+1)\sin(\frac{1}{k+1})}\right|[/tex]
You are only allowed to apply l'hopital when you're in a 0/0 or infinity/infinity situation...
To evaluate this limit, you'll have to use the following:
[tex]\lim_{x\rightarrow 0}{\frac{\sin(x)}{x}}=1[/tex].
I see. Ok so I already proved that the limit as x goes to 0, of sin(x)/x goes to 1 so that is good. So I am trying to see how to get to the form of sin(x)/x from what we have, but I can't seem to do it. If I let [itex]x=\frac{1}{k+1}[/itex], then I know as k goes to infinity that this will go to 0. In addition therefore it will be sin(x). However, I am not sure how to get from [tex] \lim_{k \rightarrow \infty } \left|\frac{1}{1+(k+1)\sin(\frac{1}{k+1})}\right|[/tex]
to a usable form. Can we drop the one on the bottom to get:
[tex] \lim_{k \rightarrow \infty } \left|\frac{1}{(k+1)\sin(\frac{1}{k+1})}\right|[/tex] which thus by replacement is [tex] \lim_{x \rightarrow 0 } \left|\frac{x}{\sin(x)}\right|[/tex]
But then this is the inverse,but since it is 1, it will be 1 again? But therefore this does not show that the series converges absolutely which is what we need to show.
Any help, and thank you for the help so far?
Well, first calculate [tex]\lim_{k\rightarrow +\infty}{(k+1)\sin{\frac{1}{k+1}}}[/tex].
If you've calculated that (and if it isn't equal to -1), then you can use
[tex]\lim_{k\rightarrow +\infty}{\left|\frac{1}{1+(k+1)\sin{\frac{1}{k+1}}}\right|}=\left|\frac{1}{1+\lim_{k\rightarrow +\infty}{(k+1)\sin{\frac{1}{k+1}}}}\right|[/tex]
Ok, so can I let [itex]x=\frac{1}{k+1}[/itex] so therefore
[itex]\lim_{k\rightarrow +\infty} (k+1)\sin(\frac{1}{k+1})=\lim_{x\rightarrow 0} \frac{\sin(x)}{x}[/itex]
which is equal to 1. So now applying this to the other thing, we get 1/2. Correct? I know this is what I got when I used the approximation of sine, and since this is less than 1 it will converge absolutely.
Alright cool thank you very much for your help.
