Proving Completeness of a function space
  • Thread starter Thread starter vineethbs
    Function Space
vineethbs
Let F = \left\{f : [0, \infty) \rightarrow R, norm(f) = \sup_{x \in [0,\infty)} \frac{|f(x)|}{x^{2} + 1} < \infty\right\}
Is F complete , under the given norm ?
My approach was to look at the pointwise limit of an arbitrary Cauchy sequence, but I am not able to prove that it converges in the metric induced by the norm.
Thank you and Merry Christmas !
Hi , is the following correct ?
(an outline of the proof )
Given an arbitrary Cauchy sequence (f_{n})
we have that
\forall \epsilon > 0, \exists n_{\epsilon} \leq m < n \, s.t \sup_{0 \leq x < \infty} \frac{|f_{n}(x) - f_{m}(x)|}{x^{2} + 1} < \epsilon
g_{n}(x) = f_{n}(x)/(x^{2} + 1)
this means that \sup_{ 0 \leq x \infy} |g_{n}(x) - g_{m}(x)| < \epsilon for m, n as above
so that g_{n}(x) \rightarrow g(x) , \forall x, uniformly
which means that \sup_{0 \leq x < \infty} |g_{n}(x) - g(x)| \rightarrow 0
with f(x) = g(x)(x^{2} + 1)
\sup_{0 \leq x < \infty} |\frac{f_{n}(x) - f(x)}{x^{2} + 1}| \rightarrow 0
\forall x, \frac{|f(x)|}{x^{2} + 1} \leq \frac{|f_{n}(x) - f(x)|}{x^{2} + 1} + \frac{|f_{n}(x)|}{x^{2} + 1} which should give that f \in F ?
Thank you for your time !
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
