Proving Continuity of f(x)/g(x) at c with Given Conditions
  • Thread starter Thread starter kingstrick
    Continuity
The discussion revolves around proving the continuity of the function f(x)/g(x) as x approaches c, under the conditions that g(c) is not zero and f(c) exists. Participants explore the necessary conditions for continuity and the implications of the continuity of the functions involved.
  • Mixed
  • Participants discuss the implications of continuity for both f and g, questioning whether the continuity of f(x) at c allows for certain simplifications in their reasoning. There are suggestions to manipulate the expressions involving f and g to facilitate the proof.
Some participants have offered guidance on how to approach the problem, including the importance of showing that g(x) does not approach zero as x approaches c. Others are exploring the implications of continuity definitions and considering the use of delta-epsilon proofs.
There is an ongoing discussion about the assumptions required for the continuity of the quotient f/g, particularly the need for both functions to be continuous at c and for g(c) to be non-zero. Some participants express uncertainty about the rigor needed in their proofs.
kingstrick
Want to show that f(x)/g(x) is continuous as x goes to c given that g(c) is not 0 and f(c) exists.
|f(x)/g(x) - f(c)/g(c)| = |1/(g(x)g(c))||f(x)g(c)-f(c)g(x)| = |1/(g(x)g(c))||f(x)g(c)-f(c)g(x)-f(x)g(x) + f(x)g(x)| <= |1/(g(x)g(c))|||f(x)||g(x)-g(c)| + |g(x)||f(x)- f(c)||
Now I am stuck
Now I am stuck
You are missing some necessary conditions on f and g; namely, that they be continuous at c. You don't have any hope of proving that f/g is continuous if you don't have both f and g being continuous. It's not enough that g(c) is not 0 and f(c) exists.
I left that part out. Sorry I was trying to show where I was stuck. By staying f(x) is continuous at c, then can I state that f(x) -f(c) is zero by the definition of continuous?
In the numerator, add and subtract f(c)g(c) instead of f(x)g(x).
Depends on how rigorous you need to be. If you're not doing a δ-##\epsilon## proof, then ##lim_{x \to c} f(x) - f(c) = 0##, and I emphasize that this is a limit.
If you are doing a δ-##\epsilon## proof, then |f(x) - f(c)| < ##\epsilon_1## and similar for |g(x) - g(c)|.
That gives me |f(c)| |g(x) - g(c)| + |g(c)||f(x)-f(c)| in the numerator. Can I still claim that f(x) = f(c) ?
I don't know what you mean by that. Of course, f(x)- f(c) "is zero" at x= c. That is true because f(c)- f(c)= 0 whether f is continuous or not. Even if f is continuous, f(x)- f(c) is not necessarily equal to 0 for any other x. Perhaps you mean, not that f(x)- f(c) is 0, but that, for any \epsilon&gt; 0, |f(x)- f(x)|&lt; \epsilon for x sufficiently close to c. That follows directly from the definition of "continuous", that \lim_{x\to c} f(x)= f(c).
Thank you. We just learned about delta. I will try it that way.
Can I say
|f(x) - f(c)| <ϵepsilon/g(c)
since g(c) is a value and not equal to zero?
I am not sure how to handle the fraction
So now I have:
(\frac{1}{g(x)g(c)})|g(c)||f(x)-f(c)|+|f(c)||g(x)-g(c)|
given that |x-c|<\delta then
(\frac{1}{g(x)g(c)})|g(c)||f(x)-f(c)|+|f(c)||g(x)-g(c)|=(\frac{1}{g(x)g(c)})|g(c)||x-c|+|f(c)||x-c|<\epsilon
so to find a good delta-epsilon i would need \delta = \epsilon1 /|f(c)| + \epsilon2 /|g(c)| which i guess makes my \epsilon = the summation of the two epsilons.
But this looks like i am going down the wrong rabbit hole and does nothing to show what i do with the fraction (\frac{1}{g(x)g(c)})
**corrected
You're perhaps missing a couple of tricks here:
First, there is no problem showing that f(x) gets close to f(c), so |f(x) - f(c)| gets small.
But, that's not what you want for g(x). Showing that g(x)-g(c) is small is not going to help. Instead, what you need is g(x) not to be too small. Because, if g(x) is too small, then f(x)/g(x) is going to get large and not close to f(c)/g(c).
So, the trick is show that |g(x)| is > |g(c)/2|, when x is close to c, which allows you to control the size of f(x)/g(x). To do this, you can chose e1 = |g(c)|/2 and show that as x gets close to c, |g(x) - g(c)| < |g(c)/2|, which means that |g(x)| > |g(c)|/2.
This is a common trick. Do you see the point?
If |g(x)| > |g(c)|/2 then 2/|g(c)| >1/|g(x)|
Allowing me to state 2/|g(c)g(c)| > 1/|g(c)g(x)|
Yes.
Another idea is to prove that 1/g(x) is continuous. Then prove that the product of two functions is continuous. And, putting the two together, you have the result. This might split the difficulties up and make the thing more manageable. It is tricky!
PeroK said:
Yes.
Or just prove that 1/x is continuous where defined, and that a composition of continuous functions is continuous.
Then prove that the product of two continuous functions is continuous.
If it is given that g(c) exists and does not equal zero, Doesnt that mean 1/g(c) exists?
I guess I am asking if this is a iff statement. That if 1/g(c) exist implies that (1/g(x)) is continuous at c. Meaning that if g(x) is continuous thrn g(c) exists and given it is not 0 then 1/g(c) exists then 1/g(x) is continuous at c.
You must assume:
f is continuous at c; g is continuous at c and g(c) not = 0.
Otherwise f/g may not be continuous at c.
  • · Replies 16 ·
