Proving convergence of recursive sequence.
The discussion focuses on proving the convergence of the recursive sequence defined by x_n = (1/2)(x_{n-1} + c/x_{n-1}) for c > 0. Participants suggest using the theorem that states a monotone bounded sequence converges, prompting exploration of whether the sequence is increasing or decreasing and identifying bounds. Examples illustrate that the sequence may not consistently behave as expected, as shown with specific values for c and x_0. Additionally, the use of graphical tools like cobweb plots is recommended to gain intuition about the sequence's behavior. Overall, the conversation emphasizes the need for a rigorous proof of convergence while exploring various approaches.
Darth Frodo
Prove for c>0 the sequence {x_n} = \frac{1}{2}(x_{n-1} + \frac{c}{x_{n-1}}) converges.
This is proving difficult, I have never dealt with recursive sequences before. Any help would be appreciated. Thanks.
So, I have an idea, but I'm not sure if it proves convergence.
If x_{n} = g(x_{n-1}) then all I have to do it let x = g(x).EDIT: Upon further thought, it does not as convergence => x_{n} = g(x_{n-1}). It is not a iff situation. Back at square one.
You have the following handy theorem:
If ##(x_n)_n## is a monotone increasing/decreasing sequence and if the ##(x_n)_n## are bounded, then the ##(x_n)_n## converge.
I would start by trying to apply this one. Can you show the sequence is increasing/decreasing? Can you find a lower/upper bound?
This is a nice remark, because if the sequence converges, you can find out the limit point this way. Indeed, you have ##x_n = g(x_{n-1})##. Thus
x = \lim_{n\rightarrow +\infty} x_n = \lim_{n\rightarrow +\infty} g(x_{n-1}) = g(x)
So can you figure out what the limit point ##x## is? (of course you still have to prove it actually converges!)
So this is what I have so far.
x_0 = r r is a non-zero real number
x_{n+1} = x_n(\frac{1}{2} + \frac{c}{2x_n^2})Case 1: ##r^2 < c~ \Rightarrow## sequence is increasing
Case 2: ##r^2 > c ~\Rightarrow## sequence is decreasing
Not quite:
Suppose c = 4 and x_0 = 1, then x_1 = 5/2 and x_2 = 89/40, so neither increasing nor decreasing!
You're on the right track, though.
To see what is happening, look at the graph of
y = f(x), \text{ where } f(x) = \frac{1}{2} \left( x + \frac{c}{x} \right)
Look up material about "cobweb plots"; see, eg., http://en.wikipedia.org/wiki/Cobweb_plot . This will give you some intuition about what is happening; it is not yet a 'proof', but may help get you started.
  • · Replies 17 ·
