Proving Differentiability of a Continuous Function at x=0
DJBruce
"A real valued function, f, has the following property:
[tex]\left|f\right|[/tex] is differentiable at [tex]x=0[/tex]​
Prove that if we specify that f is continuous at 0, then f is also differentiable at 0."
Since [tex]\left|f \right|[/tex] is differentiable we know the following:
[tex]\lim_{x\to0} \frac{\left|f(x)\right|-\left|f(0)\right|}{x}[/tex] exists, which means:
[tex]\vee \epsilon>0 \exists \delta >0[/tex] st if [tex]\left|x\right|<\delta, \left|\frac{\left|f(x)\right|-\left|f(0)\right|}{x} - \left|f'(0)\right|\right|<\epsilon[/tex]
Likewise, since f is continuous at 0 we know:
[tex]\vee \epsilon>0 \exists \delta >0[/tex] st if [tex]\left|x\right|<\delta, \left|f(x) - f(0)\right|<\epsilon[/tex]
We want to show:
[tex]\lim_{x\to0} \frac{f(x)-f(0)}{x}[/tex] exists, which mean we want to show:
[tex]\vee \epsilon>0 \exists \delta >0[/tex] st if [tex]\left|x\right|<\delta, \left|\frac{f(x)-f(0)}{x} - f'(0)\right|<\epsilon[/tex]
I am not really sure where to go. I thought of using triangle inequality, but that would won't work since it implies the other direction.
Maybe you should split up in three cases:
1) f(0)>0
In this case, we have f=|f| on a neighbourhood of 0. So differentiability of f is guaranteed.
2) f(0)<0
Analogous.
3) f(0)=0
This is probably the hardest case. Try to show that the derivative of |f| in 0, must be 0. This will help...
