I Why does +bc become negative in the proof of the Euclidian Algorithm?
  • I
  • Thread starter Thread starter MienTommy
    Algorithm
The discussion clarifies why +bc becomes negative in the proof of the Euclidean Algorithm, emphasizing that the expression d/(a-qb) is preferred over d/(a+qb). The reasoning is based on the relationship between d/a and d/bc, which leads to d/(a+bc). It is explained that using a-qb simplifies the equation, allowing for a more manageable calculation. The alternative, a+qb, results in larger numbers, making it less useful for subsequent steps. This highlights the importance of choosing the correct form for effective problem-solving in the algorithm.
MienTommy
In this video, at 5:35 He has d/(a-qb) for the first part. I was not sure how he got that. Why is it not d/(a+qb)?
Because d/a and d/bc implies d/(a+bc)
Why does +bc become negative?
Mathematics news on Phys.org
It divides both.
If a=x*d and b=y*d then a-qb=x*d - q*y*d = (x-qy)*d and also a+qb=x*d + q*y*d = (x+qy)*d
The second formula less useful for the next step, however, because it would make numbers larger.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
