Proving limit of multivariable function exists
8 replies · 4K views · last reply
Anakin_k
Evaluate or show that the limit DNE.
Limit as (x,y) -> (0,0) of (x^1/3)*y^2 / x+y^3.
I tried approaching from multiple paths, and it seems that the limit is equal to 0. I used the delta-epsilon method to prove the limit but I've been stuck so far.
Any ideas on how to begin?
Thank you.
Approaching from the limit x = y^3, we get
lim = y^3/ 2(y^3)
(x,y) -> (0,0)
= 1/2
Since the value of the limit from the path x = y^3 is not equal to 0 (the value that you have been getting), then the limit does not exist
lim = y^3/ 2(y^3)
(x,y) -> (0,0)
= 1/2
When I said approaching from the limit x = y^3, I meant from the path.
Hi,
If we are approaching from the path x = y^3, then
lim (x,y) -> (0,0) of (x^1/3)*y^2 / x+y^3
= lim (x,y) -> (0,0) of (y)*y^2 / y^3+y^3 =
= lim(x,y) -> (0,0) of y^3 / 2y^3. = 1/2
That seems to make sense.
However, if we use the path y=x:
= lim (x,y) -> (0,0) of x^(7/3) / (x+x^3)
= 0
And then WolframAlpha says 0 too. Why is that?
http://www.wolframalpha.com/input/?i=limit+%28x%2Cy%29+-%3E+%280%2C0%29+of+%28x^1%2F3%29*y^2+%2F+%28x%2By^3%29
Anakin_k said:
Hi,
But then why does WolframAlpha say otherwise?
It's not always clear why WA reaches the conclusions it does. What do you conclude about WA?
I updated my post above, to show that I did try some other paths too.
So if both limits are different, then it would mean that the limit does not exist.
I guess that WA isn't perfect after all. :)
I agree. Not the first mistake I've seen it make either.
Well thanks for clarifying that up you guys.
I have one more similar question with which I need some help. I've gotten a bit further with this one but not enough:
I concluded that the limit equals 0 by trying a few paths (hopefully this time it was right):
[itex]\lim_{\{x,y\}\to \{1,0\}} \, \frac{(x-1)^2 \ln (x)}{(x-1)^2+y^2}[/itex]If [itex]0<\left\|(x-1)^2+y^2\right\|<\delta[/itex],
then [itex]\left|g(x,y) - 0\right|<\epsilon[/itex]
[itex]\left|g(x,y)\right| = \left|\frac{(x-1)^2 \ln (x)}{(x-1)^2+y^2}\right|= \left|\frac{(x-1)^2}{(x-1)^2+y^2}\right|\left|\ln[x]\right| \leq \left|\frac{(x-1)^2}{(x-1)^2}\right| \left|\ln[x]\right| = \left| \ln[x] \right|[/itex]
What would be a good choice for [itex]\delta[/itex] so that [itex]\ln[x] < \epsilon[/itex]? Plus, it seems like the way that I've worked it out so far makes the IF statement unhelpful to the process.
You might conclude it but just trying "a few" paths does not prove you will always get 0 along any path. However, in this case the numerator depends only on x so it is easy to see that the fraction approaches 0 as x goes to 1, no matter what y is.
