Proving something is commutative in abstract algebra
To prove that the operation defined by (f ∗ g)(n) = ∑_{d|n} f(d)g(n/d) is commutative, one can analyze the sums for specific values of n, such as n=6. By substituting d with n/c, where c is also a divisor of n, it becomes evident that the sums f ∗ g(n) and g ∗ f(n) yield identical terms due to the one-to-one correspondence between the divisors. Each term in the sum can be matched with its counterpart in the reverse order, demonstrating that the operation is indeed commutative. Thus, the proof effectively shows that (f ∗ g)(n) = (g ∗ f)(n) for all n.
snesnerd
If \ast : (f \ast g)(n) = \sum\limits_{d|n}f(d)g(\frac{n}{d}), show that \ast is commutative. Note that d|n says d divides n. Now I was not sure how to do this from an abstract algebra point of view although when I stare at it my though process was to maybe rewrite it somehow, which will then be easier to show its commutative.
If d|n then there exists a unique positive integer c such that cd = n.
start by writing down g*f(n).
I understand what you mean pasmith, but I don't see how that would help show it is commutative.
Put, say n=6. Write out the sum f*g(6). Then write out g*f(6). Can you see why they are equal? That's what pasmith's hint is leading to.
Okay if that is the case, would the following proof show that it is commutative:
(f \ast g)(n) = \sum\limits_{d|n}f(d)g(\frac{n}{d}) = \sum\limits_{d|n}f(\frac{n}{c})g(c) = \sum\limits_{d|n}g(c)f(\frac{n}{c}) = (g \ast f)(n)
By itself, it doesn't make any sense. You have to work in the statement of how d is related to c and supply a few words of explanation.
(f \ast g)(n) = \sum\limits_{d|n}f(d)g(\frac{n}{d}).
Note that if d|n then their exists a c such that n = cd. Then d = \frac{n}{c} and c = \frac{n}{d}. Substituting above gives us:
\sum\limits_{d|n} f(\frac{n}{c})g(c)
Now from here how would I word it to explain why \sum\limits_{d|n}f(\frac{n}{c})g(c) = \sum\limits_{d|n}g(c)f(\frac{n}{c})?
You want to explain why the set of divisors of n, and the set of numbers n/d where d is a divisor of n are exactly the same set of numbers.
Because if you consider the set of divisors of n which are cd, and you substitute \frac{n}{d} in for c then you get that n = (\frac{n}{d})d = n.
Ok, so if you sum f(d)*g(n/d) over all the divisors of n, then if you substitute the variable c=n/d (which also runs over all divisors of n) then you get the sum f(n/c)*g(c). There is a one-to-one correspondence between d and c.
But since we have that n and \frac{n}{d} are essentially the same set of numbers then then \frac{n}{c} and c are the same set of numbers so we can commute them and nothing will change/
Yes. Summing over the divisors of 6, {1,2,3,6} then f*g(6)=f(1)g(6)+f(2)g(3)+f(3)g(2)+f(6)g(1) and g*f(6)=g(1)f(6)+g(2)f(3)+g(3)f(2)+g(6)f(1). Of course, they are the same. You can match up each term in one sum with the corresponding one in the second.
9K
