Proving the divergence theorem with the Dirac delta function
6 replies · 6K views
Clara Chung
How do you prove 1.85 is valid for all closed surface containing the origin? (i.e. the line integral = 4pi for any closed surface including the origin)
I would say by inspection, if you note that for a non-spherical surface the R would in fact be a function: ##R(r,\theta,\phi)## and that ##R(r,\theta,\phi)## factors cancel out using the rules of algebra, leaving an integral of angles only.
Since the ##R(r,\theta,\phi)## factors cancel, then you can choose R to be a spherical surface with no loss in generality.
Perhaps, @Mark44 or @fresh_42 have a more rigorous set of steps.
You can use the divergence theorem. Take any volume that includes the origin. To avoid the problem at the origin you could remove a small spherical cavity at the origin. The total surface integral is zero and the surface integral of the small cavity is ##-4\pi##.
PeroK said:
You can use the divergence theorem. Take any volume that does not include the origin. To avoid the problem at the origin you could remove a small spherical cavity at the origin. The total surface integral is zero and the surface integral of the small cavity is ##-4\pi##.
How to get 1.100 from 1.99? I can't find the derivation in the book...
That's just a substitution ##\vec{r}## to ##\vec{r} - \vec{r'}##.
How do you do the substitution? Why is it ok to let ##\vec{r}## = ##\vec{r} - \vec{r'}## ? They are not equal..
In general, if ##f'(x) = g(x)##, then ##f'(x-a) = g(x-a)##. It's a simple application of the chain rule.
