Proving the Intersection of Open Sets is Open
  • Thread starter Thread starter enricfemi
    Intersection Sets
The discussion focuses on the properties of open sets in topology, specifically addressing the intersection of open sets. It is established that while the intersection of a finite number of open sets is open, the intersection of an infinite number may not be, illustrated by the example of nested open balls whose radii approach zero, resulting in a single point, which is closed. Participants emphasize the importance of the definitions of open and closed sets, particularly in different topological contexts, such as metric spaces versus general topologies. The conversation highlights that in the discrete topology, all sets are both open and closed, making the general statement about intersections misleading without specifying the context. Ultimately, a counterexample is suggested to demonstrate that the intersection of certain open sets can yield a closed set, reinforcing the need for clarity in definitions and conditions.
enricfemi
we can prove that:
the intersection of a finite number of open sets is open.
how about:
the intersection of any number of open sets?
it's maybe not open.but how to prove it or the example?
:smile:
Mathematics news on Phys.org
In the subject of topology, the first statement you make is part of the definition of open sets.
The second statement isn't true. For example in a metric space consider a nested sequence of open balls whose radius goes to zero.
thanks for reply.
can i say something like that:
the intersection of these balls turns into a point.
and a point is a closed set.
The real question is, what definitions do you have to work with? In particular are you assuming a metric space?
Yes, you have a collection of open sets whose intersection is a closed set. That alone does not prove the intersection is not open!
wait!
i thought that it should be metric space, because we need the notion of distance to define it. but
is there any difference in other space?
You don't need any notion of distance to define a topology. Halls is right, we need to know whether you're working in a specific space, ie., real analysis, or if this is an introduction to topology. What is the context of your question?
You seem to be working in a metric space, where "open set" is defined as a set where every member is contained in an open ball that is also contained in the set and "closed" is defined by the complement of a set being open. Just showing that the singleton is closed is not enough to show that it is not open. For example, in all topologies, the entire space is both open and closed and in the discrete topology, every singleton is both open and closed. You have to negate the definition of open and show that the set satisfies the definition of "not open" (An alternative is to assume that the set is open and show that this leads to a contradiction).
"Metric topology" is one specific type of topological space and we define "open sets" in any topological space. As maze said in his first response "the first statement you make is part of the definition of open sets, in general topology." It would have helped if you had given the definition of "open set" you are using. (I know several equivalent definitions even in metric topology.)
I will guess that the definition of "open set" you are using (the most common) is "a set, A, is open if and only if all members of A are interior points of A". That, in turn, means that for any point p in A, there exist some neighborhood of p that is a subset of A: for some \delta> 0, the set \left{ q| d(p,q)< \delta\right} is a subset of A.
Suppose {A_{\alpha}} is a collection of open sets and let A be their intersection. Let p be a member of A. Then p is a member of A_\alpha for some \alpha and some neighborhood of p is in A_\alpha. Now, is that same neighborhood contained in A?
You will still need to show that an intersection of open sets may not be open. Yes, you can use the example above, of which {An}= (-1/n, 1/n} so that the intersection is {0}, a closed set. But you still need to show that {0} is not an open set.
As a little hint, note that you could construct _any_ nonempty set by taking the union of singleton points, and the infinite union of open sets is open.
Still doesn't do it, maze! The "discrete topology", defined with the metric d(x,y)= 0 if x= y, 1 otherwise, has the property that ALL sets are both open and closed. The statement "the intersection of any collection of open sets is open" is TRUE in that space.
The statement "The intersection of any collection of open sets is open in all topologies" is false but to specify a counterexample you will have to be careful to specify the metric.
I didn't want to give away the whole thing, as people here tend to be a bit overzealous about not posting solutions to homework problems. However, if you take a second look at my post, you will find that it can be made completely rigorous if there exists even one set that is not open. The discrete topology is the only topology where this is not true, so it is somewhat irrelevant to the issue at hand.
so the proof of closure is not enough.i should show that the intersection of these balls is not an open set.
Thanks to all of you!
The most important you will need to specify the metric. Fortunately you only need to give a counterexample. I would recommend showing that the intersection of (-1/n, 1/n) in the real numbers, with the "usual" metric: d(x,y)= |x- y|, is not an open set. I don't think I am giving away too much to state that the intersection is {0} and taking any \delta> 0 gives a neighborhood of 0 that is NOT a subset of that set.
Thx!
