Understanding Pulley Acceleration: Newton's Third Law and Mass Ratios"
The discussion clarifies the dynamics of two masses, m1 and m2, connected by a rope, illustrating the application of Newton's Third Law. Despite m1 being greater than m2, m2 accelerates downward due to its weight exceeding the tension in the rope. The equations governing the system are M2g - T = M2a for m2 and T = M1a for m1, allowing for the calculation of the common acceleration 'a' by eliminating tension 'T'. This analysis confirms that both masses must share the same acceleration due to their connection.
  • Understanding of Newton's Third Law of Motion
  • Basic knowledge of forces and tension in a rope
  • Ability to solve linear equations involving multiple variables
  • Familiarity with concepts of mass and acceleration
  • Study the derivation of equations of motion for connected masses
  • Learn about tension in strings and its role in pulley systems
  • Explore advanced applications of Newton's Laws in mechanical systems
  • Investigate real-world examples of pulleys and their efficiency
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of motion and forces in pulley systems.
madah12
hi in this picture ( http://img26.imageshack.us/img26/8458/53487724.png ) the teacher says that even if m1 is greater than m2 m2 will accelerate down and m1 will accelerate to the right but by Newtons third law shouldn't m1 have a leftward force to the rope which should pull m2 up?
F(m2 to rope ) = -F(rope to m2)
F(m1 to rope ) = -F(rope to m1)
Newton's 3rd law says that the rope pulls m1 to the right, and m1 pulls the rope to the left (and this in turn pulls m2 in an upwards direction*). There is no force on m1 to the left.
* This upwards force on m2 acts against the weight of m2 downwards.
So as far as m2 is concerned, there are 2 forces, its weight downwards, and the tension in the rope upwards.
As far as m1 is concerned, there is a force from the rope pulling to the right.
so why does m2 accelerate downwards? since tension is up and weight is down shouldn't Fnet = 0 ?
It accelerates downwards because
a) its weight mg is greater than T, the tension in the string; and
b) the mass m1 is pulled by a force (T) to the right, and the two masses are connected to the same string.
Think about it; how could m1 accelerate to the right yet m2 not accelerate down?
Because they are connected, both masses must have the same acceleration, a.
The equation for m2 is M2g-T=M2a
The equation for m1 is T=M1a
Given g, m1 and m2 you have 2 unknowns, a and T, and two equations.
Eliminate T and solve for a will give you the common acceleration of both masses.
  • · Replies 17 ·
11K
  • · Replies 33 ·
