Pulley dynmamics involving acceleration and time-varying tension.
The discussion revolves around the dynamics of a pulley system involving acceleration and time-varying tension, particularly focusing on a scenario where a crate is dropped from a height onto a pulley system. Participants explore the implications of slack in the cable and the resulting forces and accelerations involved in the system.
  • One participant describes a setup where a crate is dropped onto a pulley system, suggesting that this will result in acceleration and time-varying tension in the cable.
  • Another participant argues that the assumption of a non-stretching cable makes the problem insoluble due to the instantaneous change in speed required when the slack is taken up.
  • Some participants propose modeling the cable as a stiff spring to allow for a linear relationship between tension and length change, suggesting the use of F=ma to set up differential equations for the masses involved.
  • There is a discussion about the movement of the stationary end of the cable and the implications of the cable going taut, with questions raised about the necessity of instantaneous changes in velocity.
  • One participant suggests that the displacement of the crate attached to the moving pulley could be half that of the crate attached to the moving end of the cable, indicating a potential approach to setting up the equations.
Participants express differing views on the implications of the cable's behavior when slack is present, with no consensus reached on how to model the system or resolve the issues related to instantaneous changes in velocity.
Participants note limitations regarding the assumptions made about the cable's properties and the mathematical modeling of the system, particularly concerning the treatment of slack and the behavior of the stationary end of the cable.
Super Kirei
I came up with this question while thinking about pulleys. Most textbook pulley problems involve the force on the load being equal to the load's weight so that there's no acceleration. But what if we had the following setup. There's an anchor on the ceiling and there's a heavy crate on the floor attached to a moveable pulley and then a fixed pulley on the ceiling near the anchor and they're all connected by a steel cable that we'll assume is strong enough to handle all tensions without breaking or stretching and light enough to be considered mass less. Rather than just pull down on the cable and enjoy a mechanical advantage of two, I build some scaffolding and put a heavy crate on top of the scaffolding and connect the steel cable to that. Then I push the crate off of the scaffolding but the steel cable has some slack so the crate is free falling before the cable becomes taut and starts to exert a force on the other crate. Let's assume that the second crate is heavy enough or falls far enough that the initial force exercted on the first crate is enough to get it moving rather than the second crate just bouncing on the end of the cable. Just eyeballing it I think they're will be acceleration and time-varying tension on the cable but I don't really know how to write the differential equation.
The "no-stretch" assumption makes this problem effectively insoluble. At the moment that the slack in the cable is taken up one end of the cable will be moving and the other end won't. Either the cable stretches a bit or the stationary end changes its speed instantaneously, implying a momentarily infinite acceleration and force.
Try assuming that the cable is a stiff spring, such that the tension in it is a linear function of the small change in its length. Then you can just do F=ma for each mass, where the force is tension in the cable, and set up the differential equations.
Why would the stationary end of cable need to change it's speed instantaneously? The end that's attached to the crate has been moving all along, it's just that the cable wasn't taut, there were some loops of cable coiled up on top of the crate. And I'm not sure how to set up the equations using F=ma. Maybe I can use the fact the the total displacement of the crate attached to the moving pulley over any given interval of time must be half that of the crate attached to the moving end of the cable.
I'm sorry, I wasn't clear. By "the stationary end" I meant the end that is attached to the crate on the floor, so is not moving at the moment that the last of those loops of slack are taken up. Once the cable goes taut, there are only two possibilities: either both ends of the cable are moving at the same speed, or the cable is stretching. Because the stationary end wasn't moving at the instant that the cable went taut, it can't be moving when the cable is taut without an instantaneous change in velocity.
  • · Replies 38 ·
11K
