Pulleys: One mass hanging between two other masses
  • Thread starter Thread starter geralt
    Mass Pulleys
The discussion focuses on a physics problem involving three masses connected by a continuous pulley system, where one mass hangs between two others. The key equations derived include the relationship between the accelerations of the masses, specifically that the acceleration of the hanging mass (m2) can be expressed as a = m2g/(total mass). Participants emphasize using Newton's second law (F = ma) for each mass to derive the tension in the string and the accelerations of the system. The solution requires eliminating tension (T) to find the accelerations of all three masses.
  • Understanding of Newton's second law (F = ma)
  • Basic knowledge of pulley systems and their mechanics
  • Familiarity with mass and gravitational force concepts
  • Ability to set up and solve systems of equations
  • Study the dynamics of pulley systems in physics
  • Learn how to derive equations of motion for multiple connected masses
  • Explore tension in strings and its role in mechanical systems
  • Practice solving problems involving multiple masses and accelerations
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of pulley systems and acceleration calculations.
geralt
Explanation: There are three masses in this problem. Two masses are sitting on two opposite surfaces. These surfaces have a space in between them, where a third mass is hanging down. These masses are connected by a continuous pulley system.
μ = 0.
The question asks us to find the acceleration of the hanging block, and the tension in the string. We are given the following hint: You will need to find a relationship between a1 (acceleration), a2, and a3. If m1 moves distance d1, and m3 moves a distance d3, how far does m2 move?
I've already determined that the acceleration of the hanging block is the average of the acceleration of the other two blocks, but I don't know where to go from there. Any help would be greatly appreciated!
The only force would be the hanging mass pulling down on the other two blocks via the pulley. So the force would be m2g, m2 being the hanging mass. The mass would be the total masses of the three blocks. Then using f=ma, I get the equation a=m2g/(total mass). I have no idea for tension...
Please help me if you can!
oy geralt! welcome to pf! :biggrin:
call the tension "T" (the string is continuous, and the pulleys are presumably massless and frictionless, so it'll be the same all the way along)
you need to do F = ma three times, once for each mass
that should give you enough equations to eliminate T and find the accelerations!
show us what you get :smile:
  • · Replies 17 ·
  • · Replies 22 ·
  • · Replies 102 ·
  • · Replies 30 ·
