Pulling or pushing a piston slowly - Heat transferred?
  • Level: Undergrad
  • Thread starter Thread starter MechRocket
    Heat Piston
2 replies · 4K views · last reply
MechRocket
i know if you push or pull a piston QUICKLY, no heat is transferred (adiabatic process).
But what if you push or pull a piston slowly? would heat be transferred in or out if you Push slowly? Pull slowly?
why?
thanks. i can't find the answer in my book, they just talk about the Quickly case.
1. May i assume you are asking about the typical piston with compression rings? 2. would you like non Physics degree guys input on this matter or prefer to keep it in the degreed realm. answer will not offend, just do not want to waste your time
why?
Most psysics books will only talk about 2 cases, the adiabatic case, where you move the piston so quickly that no heat is transferred or the isothermal case where the piston is moved so slowly that the temperature stays equal to the surroundings.
Anything in between means the heat capacity and heat conduction of the cylinder becomes important and the problem will become much more complicated.
