Purpose of sheet resistance in thin film devices
The discussion revolves around the purpose of measuring sheet resistance in thin film devices, particularly in the context of optoelectronics and nanotechnology applications. Participants explore the implications of measuring horizontal resistance versus vertical resistance in films, as well as the relevance of these measurements during the manufacturing process.
  • One participant notes that sheet resistance is measured in applications like organic photovoltaics to electrically characterize layers, questioning the necessity of measuring horizontal resistance when vertical movement of charge carriers is also relevant.
  • Another participant argues that measuring horizontal characteristics provides valuable data about each manufacturing step without interference from layer interfaces.
  • A question is posed about whether measuring resistance in a perfectly sandwiched thin film would yield the same value as the measured sheet resistance.
  • One participant agrees that in a simple case, the values would be the same, but raises the issue of homogeneity in the film and asks for supporting literature on this topic.
Participants express differing views on the significance of measuring horizontal versus vertical resistance, with some agreeing on the simplicity of the case while others highlight complexities related to film homogeneity. The discussion remains unresolved regarding the implications of these measurements.
There are limitations in the assumptions made about film homogeneity and the potential effects of layer interfaces that are not fully explored in the discussion.
chpolyz
In optoelectronics and other nanotechnology applications (like organic photovoltaics, organic LEDs etc) most layers need to be electrically characterized among other types of measurements. Thus, sheet resistance is measured.
An example are the 4-point-probe resistivity measurements. Yet, what happens is to impose current that travels almost horizontally to the surface of the film and measure a voltage between 2 other points of the same surface.
Consider that a movement of charge carriers is realized vertically to the film surface due to voltage, in order to reach the top or bottom electrodes of the device (an organic photovoltaic in this case, which consists of many consecutive sandwiched layers)..
My question is, why do we need to measure the resistance of charge carriers that travel alongside the horizontal surface of a film? In such a way we find the "horizontal" resistance of the film and not the vertical one...
thank you
As part of the manufacturing process it is necessary to know the quality of each step in the process.
By measuring the horizontal characteristics of individual layers, data relevant to each step in the process can be gathered without the confounding effect of the interfaces between layers.
Suppose we realize a single thin film, then perfectly sandwich it between two sheet electrodes and measure the resistance. Would we expect the same value as with the sheet resistance ("horizontal" one)?
In the simple case, yes.
By "simple" you mean homogeneous film, I guess...However, what if the film were not? Can you propose any supporting literature?
Thanks a lot for your replies
  • · Replies 0 ·
