Calculating Q-Factor and Resistance for Series LC Filters
  • Thread starter Thread starter Mzzed
    Resistance
This discussion focuses on calculating the Q-factor and resistance for series LC filters. It establishes that both the DC resistance of the inductor and capacitor, as well as the load resistance, are necessary for accurate Q-factor calculations. Participants recommend creating an equivalent circuit using Thevenin's theorem to determine the effective DC resistance of all components. Additionally, it is emphasized that the resistance should be evaluated at the operating frequency due to variations caused by skin effect and dielectric losses.
  • Understanding of series LC filter circuits
  • Familiarity with Thevenin's theorem
  • Knowledge of Q-factor in resonant circuits
  • Concept of AC vs. DC resistance
  • Study Thevenin Equivalent circuits in detail
  • Learn about calculating Q-factor for resonant circuits
  • Investigate the effects of skin effect on AC resistance
  • Explore dielectric losses in capacitors
Electrical engineers, circuit designers, and students studying filter design and resonance in electrical circuits will benefit from this discussion.
Mzzed
I am trying to calculate the correct component values to use in a simple series LC filter, however I am not sure which value of resistance is to be included in these equations. When talking about a series LC filter, is the resistance required for calculating q factor the resistance of the inductor and capacitor? Or is it what ever the load resistance is further down the line in the circuit?
Thanks!
Both.
Create an equivalent circuit using the DC resistance of each component, load, and source resistance.
Calculate the effective DC resistance of all series and parallel branches combined (Thevenin Equivalent). Use that resistance to calculate the Q.
Note that in this sense, Q is defined only around the resonant frequency.
Cheers,
Tom
Normally, the capacitor has a loss resistance Rp in parallel to the capacitance.
Therefore, in order to combine this resistance Rp with the series loss resistance of the inductor Ri, the value of Rp (relatively large) must be transferred into an equivalent (small) series loss resistance Rs.
Thankyou both, exact answers I needed, really appreciate it!
Tom.G said:
Both.
Cheers,
Tom
Apart from simple textbook questions, I think you need to use the resistance at the operating frequency, because DC and AC resistance differ due to skin effect and dielectric losses.
  • · Replies 30 ·
  • · Replies 19 ·
  • · Replies 41 ·
