Q regarding fixing old busted water line w/ no water in it for 2 yrs
  • Thread starter Thread starter deltapapazulu
    Line Water
The discussion revolves around the issues related to fixing an old, broken water line that has not had water flowing through it for two years. Participants explore potential problems that may arise from the lack of water, the condition of the existing metal line, and considerations for repair or replacement. The conversation includes technical aspects of plumbing, material considerations, and the implications of corrosion.
  • Experimental/applied
  • Some participants suggest that the absence of water may lead to faster corrosion due to air exposure in the line.
  • There is uncertainty about the material of the old line, with possibilities including copper, cast iron, or galvanized iron, which could influence the need for replacement.
  • Concerns are raised about the cause of the initial break and whether similar issues might lead to future failures.
  • Some participants recommend a full inspection of the line to assess its condition before deciding on repairs.
  • There are suggestions that replacing the entire line might be more cost-effective in the long run, especially if it is not buried underground.
  • Participants share personal experiences and costs associated with similar plumbing work, indicating variability based on location and methods used.
  • Discussion includes alternative methods for pipe replacement, such as using a wire mesh pulling grip, with questions about the material and strength of such tools.
Participants express a range of opinions on whether to repair or replace the water line, with no clear consensus on the best approach. Some advocate for full replacement, while others suggest targeted repairs may suffice depending on the inspection results.
Participants note the importance of understanding the specific materials and conditions of the existing plumbing, as well as the potential for hidden issues that may not be immediately apparent. The discussion reflects a variety of experiences and local practices, which may influence the recommendations made.
Homeowners dealing with plumbing issues, individuals interested in plumbing repair methods, and those considering the implications of old plumbing systems may find this discussion relevant.
deltapapazulu
Water line on a certain property has been busted for 2 years and no water in line. I am calling plumber tomorrow to get fixed and am just curious before I do that if fact that there has been no water in line would pose any particular issue to plumber just coming out and fixing that one spot where it busted. Will I maybe need to replace whole plumbing due to it not having water running in it.
Other bit of info is that it is an old metal line.
It probably wasn't completely dry, and was definitely filled with air. That could mean much faster corrosion.
Yeah that is what I was thinking :frown:
Thanks for reply!!
It will depend on the material. Some metal lines were copper.
Is it cast iron sections with bitumen lining, or is it galvanised iron.
If it fell into disuse because it was rusted in places, then it will all need to be replaced, probably with a plastic line that will not corrode in the local soil.
What is the length and diameter of the line?
Does anybody know the reason for which the pipe busted?
Could be possible for the remaining pipe to fail again soon for similar cause?
I don't know if my reply is in time for you to ask the plumber before they come out, but many plumbers now have the ability to "run a camera" through pipes to look for breaks and other issues. You could ask them if they can run a camera, and how much it will cost. It could save you money in the long run, if it shows that the rest of the pipe looks okay.
https://www.rotorooter.com/plumbing/video-camera-line-inspection/
https://match.angi.com/sem/task.Dra...6cC1baRGQ4DADaSJqIKhhoCVLYQAvD_BwE&sequence=0
Just a remark: it is often a requirement to replace subpar/old equipment without any questions or permission asked (might be also a requirement to refuse simple patching).
Also, sometimes that's the cheapest and fastest solution.
I suggest you get entire line inspected. If good, okay.
If bad, better to resolve now rather than have hidden / future leak(s). Those may cause anything from wasted water (metered ?) via sewage ingress during storms to sink-hole formation...
If the offending line is not underground, why not just get the whole thing replaced? Or at least as much as feasible.
Unless you'd rather wait until it busts again, at the most inconvenient time (like when you're away on vacation during a cold snap).
Full replacement is actually currently in the works. Local service coming out to look at it tomorrow. What is standard medium grade material for newly installed water line running from meter to house?
Should be able to get a quote tomorrow. I live in southern state where things not as expensive and distance from meter to house is about 25 yards. Wonder about what this is going to cost me.
[belated note to others who have replied: sorry for returning late to this. thank you for the good replies!]
By my experience, it'll mainly depend on the hourly rates of the bobcat doing the digging and the expert doing the plumbing.
Likely the price of the pipe will be just small part :frown:
I had one done about a decade ago. Four feet down here in Indianapolis and they horizontal drilled it: no muss no fuss and cost $2200 for 45 ft line and meter relocation. If you dig a trench think about laying a backup pipe in the trench (plastic pipe is really cheap).
I forgot to mention an alternate. (Though it sounds like it's too late.)
When we first moved into our house, construction was working on our street. The crew showed us a leak in the mains running from the street. They offered to fix it on-the-spot by attaching a metal mesh grippy thing to the copper line and used a backhoe to brute strength the old line out length-wise and pull the new line through. They charged us 700 bucks and it has been leak-free for 25 years.
I have never heard of this "wire mesh" idea for pulling pipe - is this material similar to woven wire cloth like this: Woven Wire Cloth which is made of metal (usually stainless steel) or is this plastic or nylon material? The strength must be unbelievable!
Wire mesh pipe pullers also known as Towing Socks, Chinese Fingers or Pulling Grips
And yes, I was pretty impressed myself.
Incredible. Thank you for the information - now down the youtube rabbit hole!!!
9K
16K
  • · Replies 18 ·
  • · Replies 23 ·
