Quantity of water in air at saturation
  • Context: Undergrad
  • Thread starter Thread starter lesy1
    Air Saturation Water
The discussion focuses on calculating the quantity of water in air at saturation, specifically saturation vapor density in g/m³. Participants highlight the use of the ideal gas law (PV = nRT) and Raoult's law to derive the necessary calculations. They emphasize that while the ideal gas law is generally valid, its assumptions may not hold true at 100% relative humidity. Alternative methods suggested include using psychrometric charts and published relations from ASHRAE Transactions for accurate thermodynamic properties.
  • Understanding of the ideal gas law (PV = nRT)
  • Familiarity with Raoult's law for binary mixtures
  • Knowledge of saturation pressure equations for water vapor
  • Ability to interpret psychrometric charts
  • Research the equations for saturation pressure of water vapor as a function of temperature
  • Learn how to apply Raoult's law in practical scenarios
  • Study the use of psychrometric charts for humidity calculations
  • Examine the ASHRAE Transactions for thermodynamic properties of water
Scientists, engineers, and meteorologists involved in atmospheric studies, HVAC design, or any field requiring precise calculations of humidity and water vapor in air.
lesy1
Hi,
I would like to know if somebod knows where I could find a corelation to calculate the quantity of water in air at saturation in g/m3.
I know that many equations exist to calculate saturation pressure of water vapor in air as a function of temperature. Using one of these equations and an ideal gas law the quantity of water in air (in kg/m3) could be calculated, but I think that the asumptions for ideal gas law are not valid in my case.
Regards
Jeff, thank you for the answer, although I did not find out anything new. The quantity I am looking for is also called saturation vapor density, but I cannot find any suitable model to calculate it. Can anybody please comment validity of using ideal gas law in my case.
Regards
If you assume it's an ideal gas then
PV = nRT where n is the number of moles, T is in kelvin
You can get the density from number of moles,
n = M/m = mass of water / molar mass of water (18 g/mole)
P* m / (R*T) = M/V = density
lesy1 said:
Hi,
Regards
The ideal gas law is valid. So your calculations would be correct, assuming no errors were made of course.
Redbelly, Y,
I am sure that ideal gas law could be used if humidity of air would be low, but because I have air with 100% relative humidity, something says to me, that I cannot use ideal gas law in this case.
What equations are these? The saturation pressure is dependent on more than just temperature - it will change depending on the amount of water in the air. If you meant the saturation pressure of pure water vapor, then, yes, you can determine it from just temperature.
To solve your problem, a simple way is to assume that the air and water form and ideal binary mixture. You can then apply Raoult's law:
P=P^{*}_{w}\ x_{w}+P^{*}_{a}\ x_{a}
where P is the total apparent pressure, x is the mole fraction, P superscript * denotes the pure fluid pressure, and subscripts w and a are for water and air. For the water you would use the pure saturation pressure and for air I would just assume that the pressure is roughly the total pressure. You can then determine the number of moles and therefore the mass fractions and specific volume ratios using the ideal gas law. Doing a quick calc this returned a value with about a 3% error.
Another option would be to find a psychrometric chart at the pressure in question, though this may be difficult if your pressure is far from atmospheric pressure.
Finally, you can use published relations such as from “Formulations for the Thermodynamic Properties of the Saturated Phases of H2O from 173.15 K to 473.15 K", ASHRAE Transactions, Part 2A,Paper 2793 (RP-216), (1983), or you can use more complicated (i.e. non-ideal) binary mixture relations.
Best approach IMHO would be to take some engineering handbook and read values from tables - unless you really need them in functional form.
10K
  • · Replies 24 ·
