Quantum Mechanics: Paradoxical?
74 replies · 10K views
Originally posted by wuliheron
The person who started this thread defined paradox in terms of the classical Aristotelian definition of the word. A quanta cannot be considered true or false by this definition, hence it is paradoxical.
In any logic (Aristotelian or otherwise), a noun cannot be "true" or "false". I'm not sure what you meant to say.
In any case, Mentat posted
First let me define my use of the word paradox, in this thread. A paradox is a self-contradictory statement, or one that cannot be true, but also cannot be false.
and asked if QM is paradoxical.
QM does not contain self-contradictory statements; hence, it is not paradoxical.
Wuli, the classical Aristotelian definition of the word implies that we are focusing our attention on a subset of the set of statements. Quanta are not even on the table here.
Yes, you are correct. Sorry about.
What I meant to say is that QM describes that which is neither true nor false, but the Indeterminate or absurd.
A cat being both alive and dead at the same time is self-contradictory and is neither true nor false, real or unreal. By classical standards of logic and classical definitions of the word paradox, which is being used here, it is an absurdity.
The author of this thread did not ask if QM is self-consistent alone, but whether it fits the classical definition of paradox and the absurd which it most definitely does.
Thanks very much for the responses. As I see it, I'm going to have to much more research into Quantum Theory. Fortunately, I like that!
Well, actually, I did ask if it was self-contradictory. As you know, that's my favored definition of "paradox". I think you are absolutely correct, that QM could be considered "absurd" by classical reasoning, and thus it is, in one form, paradoxical. But, I meant the self-contradictory type of "paradox".
Being alive and dead at the same time is a contradiction, inhabiting two different locations at the same time, and an entire slew of contradictions such as this are possible according to QM.
Greetings !
You are correct of course that everything can be viewed as paradoxical, but this defeats the usefulness of logic which is demonstrable. Therefore we choose a starting point and an end point for logical arguments. We impose limits upon words and discussions for the sake of practicality.
An effect without a cause is what is commonly called magic, the supernatural, or absurd. Logic and reason are both founded upon the concept that some things are just patently absurd (note: an imposed limit) and paradoxes are one of these.
A cause without an effect is about as paradoxical as anything ever gets, a rudamentary paradox that defies the principle of synergy. It is the equivalent of saying you can have an up direction without a down, an outside without an inside, etc. or in other words, anything is possible.
What's up with you in this thread wuliheron ?
You're (delibratly ?) twisting things. I never
said ABSENSE of cause - I said they get messed up.
I believe that the true absense of cause is indeed
impossible to formalize in the form of any
reasoning system - it hits right on the rock bottom =
the PoE. However, that is NOT the case in QM (I'd
think you'd know that :wink:).
Anyway, rereading the original definition of paradox
which Mentat introduced here ("cannot be true, but also
cannot be false") I tend to agree that this particular
type of paradox indeed exists in QM.
HOWEVER, it should be noted that the above definition
of paradox is true here when viewed from the perspective
of one who adopts "normal" logic. In "QM logic" a dead/
undead cat CAN be true.
So in fact, the paradox as defined in this thread
is one that depends upon perspective really. ALL
paradoxes can not be proven as absolute, but some
remain "solid" - unsolved for now. That is not the
case with this one - it is only real in one particular
reasoning system (that most of us happen to adopt :wink:).
Live long and prosper.
Originally posted by drag
Greetings !
Sorry, but I don't know that. The only recognized "cause" for Quantum Mechanical events is random chaos. In other words, QM implies the entire universe and existence itself may be magical.
Yes, but this is contradictory paraconsistent logic that defies everyday observation. In other words, a paradox by certain definitions.
reasoning system (that most of us happen to adopt ).
Paradoxes are not proven to be absolute or relative, quite the contrary their very existence much less their definition is as vigorously debated today as it has been historically. What has changed is western science's acceptance of their usefulness.
Greetings !
Actually, you missed something. You see, a dead/undead cat can be true, but it seems (seems, mind you) to contradict itself. By classical/usual reasoning dead - being the opposite of living - doesn't allow for the entity to also be living.
HOWEVER, it should be noted that the above definition of paradox is true here when viewed from the perspective of one who adopts "normal" logic. In "QM logic" a dead/
"Normal" logic can be applied to QM; what changes is the set of premises to be used.
The apparent problems between "normal logic" and what you call "QM logic" is not the rules of logic, but the assumptions we usually make ("a cat cannot be dead and alive at the same time"). When using the right set of premises, QM works perfectly fine, without the need of a "new logic".
The problem is similar to what happens while learning relativity: in different reference frames two events can have different time orders, and as long as you keep the assumption that simultaneity is absolute, you can only regard the effect as "illogical" or "self-contradictory", which it is not.
Maybe (in a very restricted sense). But it is fair to say that such statement overlooks the very many symmetries and constraints that strongly regulate quantum behavior.
Also worth mentioning is the fact that the terms "cause", "random" and "chaos" are not the technical ones, but their "normal use" versions.
Well,... if by "magic" you mean "that which behaves in a way incompatible with everyday observations/common sense/perceived laws" then yes, quantum phenomena are "magical".
Greetings !
Indeed. However, I must point out that that
means stretching the bounderies of "normal logic"
a lot according to some defintions of it.
What's yours ?
Ha ! That is NOT what we're discussing.
The HUP is a BASIC principle of QM. It is as
basic as the particles and space-time for example
in other theories. Hence, it is NOT "magic"
unless you consider all the other basic things
in physics to be magical too(which may be the
case, but was not part of this discussion).
The HUP is ordered - it is limmited by rules of a
physical theory - it is NOT total chaos, which
would indeed probably(never can be certain :wink:)
defy explanation.
Whay was discussed here(as far as I'm concerned) is
the possibility of stuff like cause after effect and
simultainity. And these effects can be "normalized"
when viewed through the appropriate reasoning
system or possibly through different assumptions
in our r.s. like ahrkron mentioned (although I'm not
sure how this is still supposed to remain our "normal"
r.s. in such case).
What's a reasoning system ?
It's a system that accepts certain principles as
basic - axioms. So, in QM when you accept its
axioms the rest is a natural result. As for the
axioms themselves having no apparent reason or
explanation - well, that's always the case in
physics(so far and probably forever).
That's exactly my point...:wink: It's self-contradicting,
that is - paradoxical according to the definition
you introduced in this thread - FOR "normal"
logic (with its current premises, at least).
But in "QM logic" it is perfectly fine because
the theory clearly states - it is a basic
result of its axioms - that before we actually
observe the cat we can assume he is in that
state (even in the REAL world).
Although, I heard that modern experiments indicated
that WF collapse is very delicate and hence the
above (a whole cat ! ) is extremely unlikely -
but it IS possible still according to the theory.
Which is also exactly why Shcrodinger thought
of this example - a demonstration of the new
"reality" of QM - the one that makes sense for it.
Greetings !
defy explanation.
Exactly what the HUP describes is the huge debate in QM. To claim you have the answer that has evaded physicists for over a hundred years is rather arrogant to say the least. That everything in physics may ultimately be magical and without a cause implies paradox, thus it is exactly what the discussion is about.
r.s. in such case).
The question is not what is a reasoning system, but does QM defy classical logic by presenting a genuine paradox. The answer is most emphatically yes, it certainly does appear to do that.
Ahkron has attempted to redefine the concept of "truth" in classical Aristotelian logic as "reality" in my opinion, but this defeats at least half the purpose of logic. Logic is not aimed so much at affirming or describing the truth, but instead is more pointedly aimed at discerning the truth.
Aristotle himself used absurdities to support the validity of his logic. These absurdities he used are essentially no different from the ones described by QM, that is, contradictions and paradoxes. Thus either we decide Aristotle was just speaking in paradoxes and we can interpret his logic and QM anyway we want or we assume he was attempting to create a useful method of analysis as he clearly said he was and as all his actions indicate he was.
Whether QM is viewed as a paradox is dependent upon your view of reality. I think QM is viewed as a mystery when relative to a materialist's viewpoint. However, the fundamental indeterminism of
source-energy is to be expected in relation to my own philosophy, and everything actually makes sense. I.e., there is no 'paradox'.
It's not so important that you discuss my philosophy. What is important is that you realize that universal-phenomena can sometimes seem like a paradox/mystery in relation to our beliefs about reality. And clearly, those beliefs are open to debate. So, therefore, is any discussion about 'paradox'.
Exactly what does and doesn't make sense, what is and isn't a paradox by whatever standards you might care to use, is another issue altogether. Please stay on topic.
The topic asks if QM is paradoxical. I don't think it is, since the indeterminism of QM is to be expected within my philosophy. You, however, do think that it is, since your philosophy of existence mirrors a materialistic reality. I was merely pointing-out that the view of any individual within this topic is utterly dependent upon his/her underlying philosophy.
Again, this thread specifically asks if it is paradoxical by the standards of Aristotelian logic.
In addition, my philosophy is about as far removed from materialism, realistism, or idealistic philosophies for that matter as you can get. At the same time, it does not discount these philosophies but instead, includes them. Such confusion over just exactly what my philosophy is and isn't is quite common. Paradox is as slippery a concept as you can find and possibly ultimately even ineffable.
Hense, my philosophy is simultaneously both a target for attacks and a welcome matt for any and all. You alone can decide which it is for you at any given moment. :0)
By the standards of Aristotelian logic the concept of actual infinity is paradoxical. In addition, as I've already pointed out, Aristotelian logic is founded upon faith in the concept of the absurd. Hence, your own philosophy is absurd and paradoxical by the standards of Aristotelian logic no matter how much you care to deny this.
But to claim that he cannot have it, simply because others before him have not gotten it, is much to complacent, and destroys the need for any further research into the matter.
Well that's a good point, and you are correct. However, the specific philosophy that I'm looking for is the one that Schrödinger used. I want to understand why theoretical physicists don't think that the "Schordinger's Cat" phenomenon is paradoxical.
BTW, I have no opinion either way, right now. I just want input, so that I can create an opinion.
Schrödinger's Cat is not paradoxical primarily due to the logical consistency of a theory's plausibility. Economy is another, and famously encapsulated in Occam: "Do not multiply entities beyond necessity."
The "many worlds" hypothesis for example, which enjoys some appeal, makes nonsense of this principle of economy. Another time honored criterion of empirical science consists in the question of whether the phenomena at issue are open to public inspection. Therefore we must ask: Can we observe these other worlds? Or must we remain forever "blissfully" ignorant of them? A third criterion bears directly on fundamental symmetries of nature and their related conservation laws: Do these hypothetical worlds possesses mass/energy? If so, where does this mass/energy, a conserved quantity, come from? Another problem concerns the wave function itself: It supposedly evolves smoothly, except when being observed, which is happening continually. So the wave function is smooth, except when it's not, which is all the time.
Greetings !
What are you talking about ?!
I wasn't talking of any interpretation !
I was talking about the well defined and known
formulas energy/time and mommentum/location
uncertainties. These are strictly defined
through the theory's equations.
Nope, we're discussing Mentat's definition not the PoE.
:wink:
the truth.
I strongly agree with what you're saying about
the purpose of an r.s. and logic in particular.
You'll notice that I aksed ahrkron about his
definition of "normal" logic. And now that you
come to remind us of the main purpose of an r.s.
I think I'll return to my original opinion -
that QM violates "normal" logic.
I respect ahrkron's "premises" argument but
what's the point really in having an r.s. that
can change its premises like that ? If you
want an r.s. that can tell you something about
the Universe - be of use, you need to limmit -
focus it as much as possible. And if it fails -
get a new one.
Greetings !
Instantaneous teleportation through walls, being in two places at the same time, etc. is magic. Sure, the equations are nice and quite respectable, but the things they imply are outrageous. The HUP itself is the center of all this attention because of its indeterminacy.
Where have you been. This is what Mentat defined as a paradox:
By definition anything that defies such a strict Aristotelian logic is either axiomatically false or magical.
get a new one.
Or, you simply need to be flexible. This is what Quantum Mechanics provides through the ambiguity of Indetermancy. Describes not only the more mechanical and predictable Newtonian Mechanics of everyday existence, but also the bizarre realm of the wavefunction.
What does "r.s." stand for?
(reasoning system?)
You'll notice that I aksed ahrkron about his definition of "normal" logic.
First order logic (propositional logic plus quantifiers).
I think you are confusing logic (the structural rules to make inferences) with content (which has to do with the premises used).
The logic used in QM is not "abnormal" in any sense. It produces inferences in exactly the same way as your everyday logic. The difference is in the realization that many things we usually assume (i.e., use as premises) in everyday life do not hold for small objects.
A simple example of that is that, for everyday objects, it is true that
A system has to be in a single definite state at all times
so that, when you learn that
System A has only two possible states: A1 or A2
and that
Today, system A is on state A2
You can conclude that
Today, system A is not on state A1
In QM, on the other hand, the first assumption (A system has to be in a single definite state at all times) does not hold.
Such being the case, it is clear that even if you learn that the other two premises are true, you still cannot reach the same conclusion.
This is not because a different "logic" is used, but because many of the "starting assumptions" we normally use in everyday life are not applicable at the high energies/small scales of the quantum realm.
I respect ahrkron's "premises" argument but what's the point really in having an r.s. that can change its premises like that?
Science works like this. It tries to extract the minimum set of assumptions that can account for observed phenomena. When new data is gathered that contradicts the current model, such assumptions are scrutinized and modified if necessary (think of C violation, P violation and CP violation: all of them were thought to be valid assumptions until experiments showed otherwise).
... actually, the one thing that does not change is the inference system.
... actually, the one thing that does not change is the inference system. [/B]
Exactly, but it is an inference system ultimately based on Indeterminacy or paradox.
Not at all. The indeteminacy is not even an assumption!
The assumptions of QM are statements about hermitian operators, eigenvalues, measurements and probabilities. They are all (both the postulates and the concepts they're built upon) well defined and unambiguous.
The HUP can be derived from these postulates, and it does not mean that measurements are "self-contradictory"; in a sense, quite the contrary: they show that, upon measurement, a quantum object will show either its "wave" aspect or its "particle" aspect, not both.
Also, I tried to make clear that the inference system has nothing to do with the HUP.
To make it clearer: the inference system used to develop, learn and do research on QM is normal everyday logic (not even modal, fuzzy, paraconsistent or any other sort of fancy logic).
The difference is not on the reasoning system, but in the initial assumptions. It is those assumptions that allow for conclusions that conflict our everyday experiences.
How do you think a researcher makes inferences about QM? by saying "here, I conclude that the answer is YES, but since QM allows contradictions, then it is also NO"? or "then, by paradox, the result is..."?
Predictions, models and interpretations are developed using formal reasoning of the same kind you find in any calculus or geometry investigation, without any reference (or assumption) about the "paradoxical" character of some people's account of the theory.
Theoretically, there are only two possibilities. Either the wavefunction is a crazy unimaginable state like shrondenger's cat or a new universe is created for everything that doesn't happen in this one. If either one of those makes perfect sense to you there is a rubber room waiting for you somewhere.
The "magic" and "craziness" of QM is not on the wavefunction, but in the effect that a measurement has over it and, mainly, in the unjustified expectation that quantum systems should agree with classical mental models.
Not necessarily, but even if that was the case, scientific models may be surprising and (again) very different from your everyday-life ideas, but why do you think models are proposed (and later on accepted)? It is precisely because, once all details are investigated thoroughly, they do make sense of known experimental results. That is precisely what science is all about.
Again, the fact that QM is seems to conflict daily life experiences comes from the fact that if you assume daily-life rules to work on atoms, then calculate what you should see, and then make an experiment, the result of the experiment does not match your calculation.
Once you make many more experiments and find a model for how the atom behaves, you end up:
1. understanding that there were many hidden assumptions on the original calculation,
2. realizing that those were unwarranted assumtions, that do not hold at quantum level,
3. finding that using the right assumptions for the behavior of quanta, not only the original experiment makes sense, but also many other macroscopic behaviors are explained.
It is differerent from what "common-sense" expects, but it does make sense.
Don't forget that "common-sense" or "normal-logic" is basically a set of assumptions based on a very limited set of conditions (small velocities, small energies, "meduim" sizes, low temperatures, low pressures, small gravitational fields) and filtered through a very useful, but also very limited, set of perceptual mechanisms. The fact that many of those assumptions are wrong should not be a big surprise, neither be food for assuming that the conflict comes from "essential paradoxes". The conflict is a rather natural result of the limited range of what constitutes the human perceptions.
That assumes that the Many Worlds theory is false, which has not been proven. According to Quantum Decoherence and the Many Worlds theory observers and measurements are irrelevent. All of the possible states are present in the system to begin with and one is realized locally upon interacting with anything.
No, it is not merely everyday experience QM conflicts with, it conflicts with formal logic. This is a much deeper issue than simply conflicting with what we are used to. The Earth is round even though for millennia we thought it was flat, that is a simple conflict with human perception of reality but QM is another animal entirely. It insists in a sense that the Earth is both round and flat at the same time or a new Earth is created everytime and interaction takes place.
It may be that theories like M-theory may eventually provide some kind of reasonable explanation for QM, but it hasn't happened yet.
Greetings !
(reasoning system?)
Yep, too long to write it all the time. :smile:
I ask forgiveness for my ignorance, but I'm not
aware of the official definitions of these terms yet.
(Tom suggested this Karl Popper Web site, but I didn't
have time to take a serious look at it.)
How can you have independent structural rules ?
The PoE makes any absolute rules impossible.
It seems useful and more potenitally rewarding
to me to limmit and focus one's r.s. as much as
possible - thus achieveing maximum results -
exploitation of each system. (Of course, when the
system eventually leads to a problem(as it must :wink:)
it's probably more usefull to ty other systems.)
I realize that my ignorance is evident here
because the distinction you indicated - structural
rules/inferences is probably the one currently accepted,
but eventually I can't view such distinction as
more than historical scientific development based or
in other words sentimental attachment - because the
discoveries of the past are not an indication for
future discoveries(as was shown many times).
In my case, these premises are part of the r.s.
I would call "normal" logic. In "my QM" logic the
premises are those of QM and hence everything (the
parts of QM)make perfect sense.
"Simplicity is the ultimate sophistication."
Leonardo Da Vinci
